Abou to purchase B18C5 motor HELP!~!
Please explain to me what I should look out for when I buy this motor and trans except for it being stolen.
What are the basic. I am not a novice nor a professional.
So help a brother out.....
complete swap includes
motor under 40k
tranny w/lsd under 40k
ecu
harnness
axles
this is a real type-r swap
IF the motor and trans was bad, would it still be worth it.
he is selling for about $2000
thanks in advance!
motor under 40k
ecu
harnness
axles
thanks in advance!
thats too good to be tru unless the guy does not know whta he has.
check for green pain on the head by the dist.type r should have them. tranny should say j4d, b18c5 if u.s. motor. manifold should be stamped p73 and look at the bolts make sure no one has opened up the motor before.
There are three possibilities here.
A) The seller is a scammer, and knows that someone is likely to send him money without seeing the motor first, and he dissapears. This would be easy because there are many people that would spend $2000 on an ITR swap without seeing it or knowing the history of the seller.
B) The motor is stollen. This is the most likely the case, because $2000 for a legit motor is unheard of, unless the person has absolutely no knowledge of what they have...but who sells an ITR motor and NOT know what it is? And judging by the "this is a real ITR swap" sentence in the add, I would assume he/she knows exactly what they have.
C) The motor is blown, and someone is just trying to sell a big parts bin.
I say get the VIN # immediately, and if the seller does not have the VIN# on the motor, call the proper authorities, because I believe it is a LAW that the VIN must be present on the motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">There are three possibilities here.
I say get the VIN # immediately, and if the seller does not have the VIN# on the motor, call the proper authorities, because I believe it is a LAW that the VIN must be present on the motor.</TD></TR></TABLE>
Well said. Something just doesn't seem right about this.
this person hasn't got back to me yet.
thanks for all the input.
he is somewhat local to my area so I will physically see the motor before buying.
I know this might sound like a newbie question, but how can I tell if the motor is blown?
Go look at the motor, and check the VIN number on the block. If it is removed, tell him you are "going to bring a chasheirs check" the next time you come, but instead of the check, bring a cop.
or D) The guy took way too much Ecstacy and is feeling very generous.
ya thats too good to be tru. Only way I believe that is if it was a old man selling it. Y sell it for 2000 when you can get 4000 out of it easy??? Something is wrong with it
95civickid
Mar 13, 2005 11:50 PM
