will an itr header fit on my gsr?
Old Sep 11, 2003 | 08:42 PM
sExy_TinKY's Avatar
Default will an itr header fit on my gsr?
i was just wondering if an itr header will directly bolt on to my 95 gsr? and if not, what will i need to make it fit?
thanx all!!
Old Sep 11, 2003 | 08:50 PM
B00ST2nR's Avatar
Default Re: will an itr header fit on my gsr? (sExy_TinKY)
you're talkin about the JDM ITR 4-1 header right?
Old Sep 11, 2003 | 08:51 PM
sPaRk'iT's Avatar
u will need to replace your cat to a 2.5 collector, and maybe add or take off 4inch to your exhaust pipe if you have a gsr, or if you have a ls then you wont need to do anything to your pipe, just the cat. Somebody correct me if im wrong.
-Bruce
Padawan's Avatar
Darth ModerVader
Neither USDM nor JDM ITR manifolds will bolt directly to a '95 GS-R without modifications to the cat.
Old Sep 11, 2003 | 09:09 PM
Smitdog's Avatar
Default Re: will an itr header fit on my gsr? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Neither USDM nor JDM ITR manifolds will bolt directly to a '95 GS-R without modifications to the cat.</TD></TR></TABLE>
Old Sep 12, 2003 | 01:56 PM
sExy_TinKY's Avatar
Default Re: will an itr header fit on my gsr? (Smitdog)
crud....thanx guys.
o btw i was referencing to a USDM ITR header..should have specified that * on me*
Old Sep 12, 2003 | 02:24 PM
Blk95GSR's Avatar
the primary flanges are the same on both.
Old Sep 25, 2003 | 06:26 PM
95lsteg's Avatar
Will it fit an Ls ??
Old Sep 25, 2003 | 06:31 PM
Padawan's Avatar
Darth ModerVader
Default Re: will an itr header fit on my gsr? (95lsteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lsteg &raquo;</TD></TR><TR><TD CLASS="quote">Will it fit an Ls ??</TD></TR></TABLE>
Yes, direct bolt-on.
Old Sep 25, 2003 | 07:21 PM
B2FiNiTY's Avatar
Just to get the info out as many have in the past.
USDM 97-01 Integra Type Header will BOLT ON to the following vehicles:
00-01 Integra GSR
97-01 Integra Type R
94-01 Integra LS/GS/SE/RS
wing.jai
Jun 4, 2009 12:31 AM
stiness101
Aug 23, 2006 06:56 PM
StayTuned12
Aug 17, 2005 10:31 AM
TheSquirrel
Dec 12, 2004 08:37 PM
MRDC2
Jul 31, 2001 12:42 PM
