Is a type R ECU, skunk manifold, Spoon t/b, and Type R intake worth doing?
Old Sep 11, 2003 | 07:52 PM
4505's Avatar
Default Is a type R ECU, skunk manifold, Spoon t/b, and Type R intake worth doing?
I currently have i/h/e and type r cams.
Old Sep 11, 2003 | 07:54 PM
Dan GSR's Avatar
Default Re: Is a type R ECU, skunk manifold, Spoon t/b, and Type R intake worth doing? (4505)
what motor?
gsr?
b16?
Old Sep 11, 2003 | 08:19 PM
4505's Avatar
Default Re: Is a type R ECU, skunk manifold, Spoon t/b, and Type R intake worth doing? (Dan GSR)
Sorry 2000 gsr
Old Sep 11, 2003 | 09:03 PM
iH8RICERZ's Avatar
sure thing it is..for a reliable all motor set up it is. i have the skunk2 IM, itr intake, ctr intake cam, but running a chipped p28 w/ my custom all motor program...and it KICKS *** !!! w/o the skunk IM, chipped p28, and itr cai, i was running 14.8-15.0, now i'm running 14.5
Old Sep 11, 2003 | 10:09 PM
B2FiNiTY's Avatar
Definately worth it
Old Sep 11, 2003 | 10:18 PM
HYREV2NR's Avatar
Sounds good but I rather get an OBD1 ecu re-chipped or get Hondata.
Old Sep 11, 2003 | 10:19 PM
threatcon13's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4505 &raquo;</TD></TR><TR><TD CLASS="quote">Is a type R ECU, skunk manifold, Spoon t/b, and Type R intake worth doing?
I currently have i/h/e and type r cams.</TD></TR></TABLE> everything but the spoon t/b is "worth" doing. you could get an ericks racing tb or have your tb bored out for a significantly lower price.
Old Sep 12, 2003 | 02:47 PM
4505's Avatar
Default Re: Is a type R ECU, skunk manifold, Spoon t/b, and Type R intake worth doing? (Threatcon13)
Thank you guys Ericks throttle body requires me to remove and install the tps sensor. Erick says he can do it for $60. I'd rather get a Spoon t/b.
Old Sep 12, 2003 | 02:58 PM
obd2gsr's Avatar
sounds like a good list of mods to get. you can get the spoon T/B, but u'r probably better off buyin an FPR and some dyno time and tuning the cams with the i/h/e, intake manifold, and fpr.
Old Sep 12, 2003 | 03:03 PM
00 FBP ItR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4505 &raquo;</TD></TR><TR><TD CLASS="quote">Thank you guys Ericks throttle body requires me to remove and install the tps sensor. Erick says he can do it for $60. I'd rather get a Spoon t/b.</TD></TR></TABLE>
wtf.. to remove the ******* tps sensor.. thats BS!!!
The shop I go to charged me <U>$5!!!!</U>
and the Spoon throttle body isn't a real 70mm, it tapers back to stock size
Old Sep 12, 2003 | 03:15 PM
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4505 &raquo;</TD></TR><TR><TD CLASS="quote">Thank you guys Ericks throttle body requires me to remove and install the tps sensor. Erick says he can do it for $60. I'd rather get a Spoon t/b.</TD></TR></TABLE> why? you can remove and reinstall the tps yourself. why pay 450 bucks for a spoon throttle body?
Old Sep 12, 2003 | 03:22 PM
Rob Dizzle's Avatar
I would wait for the new aebs intake manifold. or get your gsr IM ported and polished. can run from 100-300 depending upon time spent to do it.
type r ecu isnt worth it. just get a hondata setup or vafc
what i/h/e do you have?
you could put that money into getting a real header, ie, smsp or hytech and others
u have cam gears too?
Old Sep 15, 2003 | 08:36 AM
4505's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote"> why? you can remove and reinstall the tps yourself. why pay 450 bucks for a spoon throttle body? </TD></TR></TABLE>
I don't know how, there aren't screws to take off. Even if I am able to get it off, how do I adjust the TPS sensor?
I have a Comptech Ice Box, JDM type R 4-1 headers, Carsound cat, and RSR exhaust, B&m Fpr and gauge, Civic Type R cams, and Toda Cam gears
lejeaune
10
Jan 8, 2008 09:53 AM
tmrtwo
Dec 25, 2006 08:53 PM
Metamorfasis
Jan 2, 2006 05:57 PM
ThinHoanG
22
Apr 20, 2005 08:39 PM
SPOON 1
Jun 1, 2003 09:20 AM
