Best Big Bore Trottle Body
Old Sep 11, 2003 | 07:15 PM
Big Teggie's Avatar
Default Best Big Bore Trottle Body
What big bore throttle bodies is everyone using?
Ericks Racing ?
STR ?
RPM Services ?
They all offer simlar sizes and the designs look close.Which has the best quality, and works well?
I dont want to get one with a throttle plate that sticks or has any problems.
Old Sep 11, 2003 | 07:59 PM
HONDABROMANDUDE's Avatar
Default Re: Best Big Bore Trottle Body (Big Teggie)
I have an Erick's 68-66mm one and it works well. The only complaint is how stiff my throttle pedal is now. Anyone know how to make it less stiff?
Old Sep 11, 2003 | 08:31 PM
kwik93si's Avatar
i got the 70mm str and it's work really well.
Old Sep 11, 2003 | 08:34 PM
migs's Avatar
Default Re: Best Big Bore Trottle Body (itec311)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itec311 &raquo;</TD></TR><TR><TD CLASS="quote">I have an Erick's 68-66mm one and it works well. The only complaint is how stiff my throttle pedal is now. Anyone know how to make it less stiff?</TD></TR></TABLE>
I believe that is from the spring on the TB.
Old Sep 11, 2003 | 09:32 PM
TEAMGENDAI's Avatar
Default Re: Best Big Bore Trottle Body (Migs)
I might be wrong but i believe all the throttle bodies you have listed are made by the same person. If not they sure do all look alike. So it would just a prefrence thing??????
Old Sep 11, 2003 | 11:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Migs &raquo;</TD></TR><TR><TD CLASS="quote">
I believe that is from the spring on the TB. </TD></TR></TABLE>Any ideas on how to make it softer?
Old Sep 12, 2003 | 06:27 AM
kungfuSiR's Avatar
i'm using a 68mm RPM services TB, and i like it, sticky throttle plate though, but i fixed that
Old Sep 12, 2003 | 06:39 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie &raquo;</TD></TR><TR><TD CLASS="quote">
I dont want to get one with a throttle plate that sticks or has any problems.</TD></TR></TABLE>
stock ITR bored out similar to Spoon ...
Greg
Old Sep 12, 2003 | 08:59 AM
GreenR's Avatar
Does anyone make a 70mm TB for K-series?
Old Sep 12, 2003 | 09:02 AM
AllMoToRB18c's Avatar
Default Re: Best Big Bore Trottle Body (GreenR)
what about a JG TB?....does anyone have one of those and if so are they just as good as all the other ones?
Old Sep 12, 2003 | 09:09 AM
2point6's Avatar
Mark, does the TB stick on opening or is it through its entire movement?
Old Sep 12, 2003 | 09:29 AM
allmtr's Avatar
Default Re: Best Big Bore Trottle Body (2point6)
i had a spoon 70mm tb on my ls/vtec and it was great. i now have it on my b16 and its waaayyy too big
Old Sep 12, 2003 | 09:36 AM
Drag R's Avatar
Default Re: Best Big Bore Trottle Body (allmtr)
i was thinking about having Inline Four bore my stock one out.
70 w/ 68 Taper. Anyone ever try these out?
Old Sep 12, 2003 | 09:59 AM
mr. wu's Avatar
Default Re: Best Big Bore Trottle Body (Drag R)
im running a 70m BBK throttle body. it works pretty good, and i got it for a really good price
Old Sep 12, 2003 | 10:15 AM
skunked's Avatar
Default Re: Best Big Bore Trottle Body (AllMoToRB18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMoToRB18c &raquo;</TD></TR><TR><TD CLASS="quote">what about a JG TB?....does anyone have one of those and if so are they just as good as all the other ones?</TD></TR></TABLE>
I run A JG TB, It's a overbored OEM unit...looks like stock and has worked very well with my 1.8 putting out over 200whp.
Old Sep 12, 2003 | 01:58 PM
Big Teggie's Avatar
Thanks for all the input.
I already have a 66-64 tb, but wanted to upgrade.
I will most likely got with the STR, I found a pretty good deal.
Old Sep 12, 2003 | 07:03 PM
quikyEG's Avatar
I got a holley 68mm, looks and feels great...................whatever you do get it port-matched to your manifold. In the beginning your throttle might stick and drive funny but that goes away after a few hundred miles. good luck.........btw rpm throttles suck.
Old Sep 12, 2003 | 08:30 PM
MackSpeed-616's Avatar
Default Re: Best Big Bore Trottle Body (quikyEG)
i have a 68mm STR TB never used. $250 anybody want it let me know
*****SOLD******
Modified by MackSpeed-616 at 1:56 AM 9/24/2003
Old Sep 13, 2003 | 07:57 AM
crxste's Avatar
Default Re: Best Big Bore Trottle Body (MackSpeed-616)
I've got a JG 66mm one on my B16, plenty for me and my motor me thinks, and it looks nice in a stock kinda way
Old Sep 13, 2003 | 10:15 AM
Default Re: Best Big Bore Trottle Body (crxste)
how much does the JG go for like $315?
Old Sep 13, 2003 | 03:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 &raquo;</TD></TR><TR><TD CLASS="quote">
Mark, does the TB stick on opening or is it through its entire movement?</TD></TR></TABLE>
It's stiff through the entire movement.
Old Sep 13, 2003 | 09:38 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMoToRB18c &raquo;</TD></TR><TR><TD CLASS="quote">how much does the JG go for like $315?
$140 with core
Old Sep 13, 2003 | 10:54 PM
turbociv's Avatar
any one have any dyno results from the jg TB?? Is there any problem getting jg to do this? Last time I checked with jg they werent answering phones and rarely answering e-mails. Kinda rude through the emails too, but they never did really tell me how to do the order!!
Old Sep 13, 2003 | 11:44 PM
The Tea-father's Avatar
str 70mm work great on my b18c del sol
Old Sep 14, 2003 | 09:13 AM
TREVER's Avatar
Default Re: (fd3st04r)
I have a rpm and had a str both were good.
Freddie from str swears they make theres in house.
I believe rpm makes ericks.
