Full Race vs. LoveFab dyno challenge.....got it!
Old Sep 11, 2003 | 06:32 PM
SpeedDreamz.com's Avatar
Default Full Race vs. LoveFab dyno challenge.....got it!
Tell you what I will do. I have a manifold coming from Full Race and if Cody will oblige and send me one of his I will test both on our chassis dyno. I know LoveFab is so very far behind but I will only need it for a couple of days.
Who wants to know the results?? With Geoff and Cody's permission I will post them.
Old Sep 11, 2003 | 06:33 PM
Drew Peacock's Avatar
Default Re: Full Race vs. LoveFab dyno challenge.....got it! (30psiCiv)
Cody wont mind but I think you will find geoff will.
Old Sep 11, 2003 | 06:36 PM
Default Re: Full Race vs. LoveFab dyno challenge.....got it! (turbozxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote">Cody wont mind but I think you will find geoff will. </TD></TR></TABLE>
If either objects then no test will be done.
Old Sep 11, 2003 | 06:38 PM
Ray's Avatar
Ray
New User
I'd rather not just compare full-race vs lovefab but most of the other manifolds in the market also
https://honda-tech.com/zerothread?id=449036
Old Sep 11, 2003 | 06:43 PM
Default Re: Full Race vs. LoveFab dyno challenge.....got it! (Ray)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ray &raquo;</TD></TR><TR><TD CLASS="quote">I'd rather not just compare full-race vs lovefab but most of the other manifolds in the market also</TD></TR></TABLE>
If anyone has one they would like to submit for testing then it is welcome
Old Sep 11, 2003 | 06:44 PM
quikB18B's Avatar
I know about the whole "manifold" problem, but since when do you have to get permissin to test products Just test the damn things. I mean if i was to buy both manifolds or have them at my disposal i feel i have every right to test them and post results, i dont see anything wrong with that. Both manifolds are great, like Geoff, said it really just comes down to the buyer preference
Old Sep 11, 2003 | 06:58 PM
Ray's Avatar
Ray
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psiCiv &raquo;</TD></TR><TR><TD CLASS="quote">
If anyone has one they would like to submit for testing then it is welcome</TD></TR></TABLE>
you only looked at half the reply smart guy, click on the link https://honda-tech.com/zerothread?id=449036
Old Sep 11, 2003 | 07:02 PM
you only looked at half the reply smart guy, click on the link https://honda-tech.com/zerothread?id=449036</TD></TR></TABLE>
What is your point?
Old Sep 11, 2003 | 07:14 PM
EFb18b's Avatar
personally I wouldn't mind seeing the results of the test. Are you going to be tuning the test car with each manifold?
Old Sep 11, 2003 | 07:17 PM
Default Re: Full Race vs. LoveFab dyno challenge.....got it! (Redlineracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redlineracer &raquo;</TD></TR><TR><TD CLASS="quote">personally I wouldn't mind seeing the results of the test. Are you going to be tuning the test car with each manifold?</TD></TR></TABLE>
All manifolds will run with the same settings in Motec. I think this is the only way to be fair
Old Sep 11, 2003 | 07:20 PM
STHPERFORMANCE's Avatar
I would say do a write up on more then just Cody and Geoffs manifolds...
Try Kooks and other manufactors like Obx and stuff.....
Old Sep 11, 2003 | 07:22 PM
Boostfed's Avatar
New User
All manifolds will run with the same settings in Motec. I think this is the only way to be fair</TD></TR></TABLE>
No it wouldn't. Each manifold when installed would need to be tuned accordingly, each may or will require different fuel settings/requiremets due to airflow and spool time, let's say Full Race or even Lovefab mani actually spooled 300rpm sooner than the other mani then you would need to tune it richer there and tune the timing also. That is like saying throwing some Jun 3 or Skunk2 cams, Edelbrock intake mani and TB on and seeing if you made more power just slapping it on for comparison. Definately the new cams would need more fuel same as turbo slap a big turbo or mni on that spools quicker you'll run lean. Just my opinion though .
Old Sep 11, 2003 | 07:28 PM
SiRkid's Avatar
Default Re: Full Race vs. LoveFab dyno challenge.....got it! (Boostfed)
you could do that as as secondary thing..
test them with the exact same settings and see how each performs.. youll then get some idea of how each work and then you can tune both and then compare that aswell!
I think you need the "generic" test to get a sort of "baseline"
Old Sep 11, 2003 | 07:43 PM
rOby's Avatar
Default Re: Full Race vs. LoveFab dyno challenge.....got it! (SiRkid)
i think u should just ask geoff. hes a great guy. its common courtesy.
Old Sep 11, 2003 | 07:45 PM
EFb18b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed &raquo;</TD></TR><TR><TD CLASS="quote">
No it wouldn't. Each manifold when installed would need to be tuned accordingly, each may or will require different fuel settings/requiremets due to airflow and spool time, let's say Full Race or even Lovefab mani actually spooled 300rpm sooner than the other mani then you would need to tune it richer there and tune the timing also. That is like saying throwing some Jun 3 or Skunk2 cams, Edelbrock intake mani and TB on and seeing if you made more power just slapping it on for comparison. Definately the new cams would need more fuel same as turbo slap a big turbo or mni on that spools quicker you'll run lean. Just my opinion though . </TD></TR></TABLE>
exactly what I was thinking. You have to tune the engine to "accept" each manifold or else the test is useless.
Old Sep 11, 2003 | 08:22 PM
Turbocivic94's Avatar
I would like to see the results. I have lovefab and want to see how its compared to full race.
Old Sep 11, 2003 | 08:27 PM
sporkcrx's Avatar
Default Re: Full Race vs. LoveFab dyno challenge.....got it! (25 PSI CRX)
It'd be cool to see.
Old Sep 12, 2003 | 12:23 AM
Ray's Avatar
Ray
New User
What is your point?</TD></TR></TABLE>
My point is the link is about the same topic.
Old Sep 12, 2003 | 12:26 AM
lazerus's Avatar
i dont think he'll care.
Old Sep 12, 2003 | 02:29 AM
rjardy's Avatar
Default Re: Full Race vs. LoveFab dyno challenge.....got it! (lazerus)
Im glad some one voluntered, if not, I was going to...
Im interested to see what makes more power. But I dont think that the setting should be change to account for the manifold, I think that same setting, same enviornment, same temp, same everything is how the two should be tested. Any how i think that this is a neat idea, and just hope that it doesnt spread ill will or intentions on any one. If everyone can keep the frame of mind that this is all in good sport, and not turn it into a pissing contest (when results come out) than it will have been worth it. Lets get it going!
Rob
Old Sep 12, 2003 | 02:43 AM
Cyber ITR's Avatar
Default Re: Full Race vs. LoveFab dyno challenge.....got it! (rjardy)
i dont see numbers
Old Sep 12, 2003 | 03:38 AM
DaveF's Avatar
Default Re: Full Race vs. LoveFab dyno challenge.....got it! (Day Walker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Day Walker &raquo;</TD></TR><TR><TD CLASS="quote">i dont see numbers </TD></TR></TABLE>
look at how old the post is champ. do you honestly think that somone can get 2 differant manifolds from 2 differant manufactures, swap manifolds, and do dyno comparisons within a few days....1 day actually. the topic was posted yesterday....
come on now, be realistic here.
Old Sep 12, 2003 | 03:56 AM
rjardy's Avatar
Default Re: Full Race vs. LoveFab dyno challenge.....got it! (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">
come on now, be realistic here.</TD></TR></TABLE>
I want numbers NOW NOW NOW
Rob
Old Sep 12, 2003 | 04:21 AM
My point is the link is about the same topic.</TD></TR></TABLE>
Those are just guys talking. I am not much of a talker because talk is cheap. What I say, I do. If those guys will submit them, they will be tested. The ball is in their court.
Old Sep 12, 2003 | 04:22 AM
No, It was just posted a few hours ago.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">
