Flywheel
Old Sep 11, 2003 | 05:17 PM
97F22B2's Avatar
Default Flywheel
Im boosting my motor at 10psi and am changing the clutch and wondered if a 8.5lb flywheel would be too light for the motor. I am also conserned about if i would have extreme traction issues due to the light flywheel and spool. Holla at me.
I wanna use a Fidenza fly with an Exedy clutch(possibly ACT if i can find a good one)
Old Sep 12, 2003 | 07:20 AM
abeaujuin's Avatar
Default Re: Flywheel (97F22B2)
I am not sure on that, but my question to you is Have you done anywork to the Motor? Like pistons change block rebuild or anything like that before you installed your turbo? I am about to install a Drag turbo kit on my 94 accord with 176,000 miles on it. Just wondering if my will last at all.
Old Sep 12, 2003 | 12:05 PM
jmal1919's Avatar
I've got a 8lb CM flywheel and plan to boost pretty soon.
IMO, you can compensate for any traction issues by the way you drive. Rev just enought to get the wheels to catch, then let it go.
Old Sep 12, 2003 | 02:09 PM
97F22B2's Avatar
Default Re: (jmal1919)
my motor has seen no anything except oil, so you should be ok. i do however have a port and polished VTEC head laying around but need more funds to build internals. if i were to start again i would build the head first. F series bottom ends can hold a substantle amount of abuse, the head just doesnt flow very well.
Old Sep 12, 2003 | 02:15 PM
el arbi's Avatar
Default Re: (97F22B2)
Just takes some practice
splickitysplat
22
Mar 6, 2007 12:32 PM
lilman36
Nov 20, 2003 12:00 PM
sircrxracer
Oct 12, 2003 02:56 PM
etmoron
Aug 1, 2003 08:20 PM
lucas569
Aug 6, 2001 02:14 PM
