Light flywheel good?
Old Oct 11, 2003 | 05:27 AM
sircrxracer's Avatar
Default Light flywheel good?
Just wondering I have a Prolite ACT flywheel and was wondering should I use it in my race car All Motor??? TIA Rob
Old Oct 11, 2003 | 06:56 AM
johnzm's Avatar
Default Re: Light flywheel good? (sircrxracer)
im sure ill be onee of the few to say that a light flywheel has no place in a drag car. it made my car considerably more difficult to launch. i have no idea, tho, if it actually reduced my times becasue it was installed with the engine
Old Oct 11, 2003 | 07:21 AM
Unsung's Avatar
Default Re: Light flywheel good? (johnzm)
My setup is ACT HDSS + ACT 8.8lb flywheel... increased my 1320 about .2 over the stock clutch/flywheel setup. I love it, my favorite thing I've done to my car.
Old Oct 11, 2003 | 07:24 AM
Default Re: Light flywheel good? (Unsung EM1)
I have the ACT Hi6 6puck ceramic with the prolite flywheel
Old Oct 11, 2003 | 09:01 AM
a2snakes's Avatar
I would think that having a lighter flywheel will get you up in the RPM's faster, where most honda 4 cylinder engines shine. throw in a shorter final drive maybe?! I dunno....
Old Oct 11, 2003 | 10:06 AM
civickiller's Avatar
Default Re: Light flywheel good? (a2snakes)
get a 2 step to help with launches
Old Oct 11, 2003 | 11:07 AM
.derf.'s Avatar
Default Re: Light flywheel good? (civickiller)
i personally dont like a really light flywheel. i had a gsr motor with skunk intake, stage 3 cams, mugen headers, and a 6.6 lbs flywheel. dynoed at 180hp and only 113lbs....the problem with the light flywheels is the motor falls off when you shift. with a stock flywheel the motor keeps spinning up high cause you have weight to keep it going. i had to launch that set up at like 9k so the car wouldnt fall on its face.
Old Oct 11, 2003 | 12:32 PM
kill bill's Avatar
Default Re: Light flywheel good? (hybridKOOPHRI)
i had the clutchmasters flywheel which i believe was around 8 or 9 pounds...not super light, but light enough for me to notice the difference between a stock flywheel, regarding revs...it felt like my car was burning through the gears like a streetbike
Old Oct 12, 2003 | 08:55 AM
DC2Slow's Avatar
try ACT Streetlite...thats what i have and i love it...went back to the strip and did fairly well...added and took of some parts on my car.
Old Oct 12, 2003 | 02:56 PM
gofastgsr's Avatar
I just had the ACT 12.5 pound flywheel installed and I like it a lot. I have a GSR with the intake, header, exhaust and no cat. Definetly gets you into Vtec a little quicker.
Also shifts smoother.
leondx
Honda CR-V & Element
Mar 3, 2013 05:08 AM
integraboosted
Apr 22, 2006 05:50 PM
HitEm'Up
15
Aug 18, 2005 03:27 PM
Honsu
Mar 22, 2004 04:34 PM
Mr. 1582
17
Sep 21, 2003 06:21 PM
