is there any down side to runnin a ZC ecu on my CRX SI?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicracer1993 »</TD></TR><TR><TD CLASS="quote">does the SI ecu have that cut off? </TD></TR></TABLE>
No it doesnt but actually I think the cut off is at 100mph not 110mph for the ZC ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane »</TD></TR><TR><TD CLASS="quote">my tach
??? read 113mph when I hit fuel cut off...</TD></TR></TABLE>
You mean speedo?
And above is correct USDM ECU's don't have a speed limiter, ONLY JDM ECU's do, but you can get re-programmed off I believe.
??? read 113mph when I hit fuel cut off...</TD></TR></TABLE>You mean speedo?
I don't know honestly, I've never seen one, I'm all about USDM.
Try --- 'JDM ECU' search in archived topics.
HTH
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicracer1993 »</TD></TR><TR><TD CLASS="quote">ok so how can i tell if its usdm or a jdm ecu?
mike
Well and the fact that if it is a PM7 ecu there is no usdm PM7 the only comparable one would be the integ ecu which would be the PG7. So thats how you can tell read the side of it and see if it does infact say PM7.
mike
StupidSlowRSX
Nov 29, 2003 12:35 PM
