putting a 90-93 integra cluster in EF hatch
Alright I hav a 91 cluster out of a integra and i am looking to put it into my hatch and I need to find someone that has tha pin locations to do the wiring. I would appreciate it if anyone can help
thanx mike
thanx mike
integra cluster wiring diagram for a 91 civic dx
Modified by Kyo Babic at 6:28 PM 11/3/2003
that picture is JDM 94+ GSR right? or type r?
oh and by the way wiring is different for 88-89 and 90-91 so you might want to specify what vehicle thats for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dingusjt »</TD></TR><TR><TD CLASS="quote">that picture is JDM 94+ GSR right? or type r?
Neither, it's a cluster from a JDM 2G Integra non-VTEC. Notice the kilometers instead of MPHs.
It doesn't really fit well IMO. As you can see the cluster cover blocks the ends of gas and temp gauges. There is really no advantage to this. The stock CRX tach goes to 8K as well.
tisk tisk...ok i did this swap becuase my car is a DX therefore i had no tach also i happened to found this cluster before i found a Si cluster...also to be exact the cluster came out of a 92 integra rs and its NOT jdm....its canadian. i just so happen to live in ontario, canada
ok you need the integra's clips to make it work, and wire it up just like a integra in your EF, so that your clips match the ones in the pic
EF_kyle
Aug 3, 2017 02:34 PM
youngbuck_22
Feb 17, 2008 11:23 PM
Kyo Babic
Feb 15, 2003 06:15 PM
plus my back light just died out...
