turbo
You will need more than 300 hp to go into the 11s with a FWD car as heavy as the Type R.
A bolt on DRAG kit is not going to get you into the 11s.
Try the FI forum
Try the FI forum
you should build your engine for 11's, i woudln't push 300whp on itr without stronger pistons at least.. at least get pistons/rods.. then stronger sleves - may not be needed for 300whp.. you'll also need good fuel managment not supplied with most pre-made kits.. you can accomplish all of what you said without engine work or good fuel managment.. but at the price of reliability..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** »</TD></TR><TR><TD CLASS="quote">just sell the itr and get a lancer evo or wrx sti. save yourself lots of headaches.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ »</TD></TR><TR><TD CLASS="quote">I'm doing 12's on my current setup...so you have to do better than what i got to get into 11's...to give you an idea</TD></TR></TABLE>
I seen pics of miraiz's car and all...but 12's for an itr is daam good!, and i don't think 300 will be enough. But then again if you plan to strip it all out and do all that crazy nonsense then maybe...a 4 cyl ff drive car has problems keeping high end speed going down the track..plus u got to find a way of launching the bitch, without breaking anything! 300 hp running 12's with full interior is my goal....but then again its ur pockets that carry the cash.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-1303 »</TD></TR><TR><TD CLASS="quote">...plus u got to find a way of launching the bitch, without breaking anything! </TD></TR></TABLE>
Ain't that the truth!
i prob coulda hit 11's on my old set up if it woulda kept the tune and on slicks , i did 12.80 on 1 run on street tires untuned on 8psi
btw i coulda done over 300whp with ease if we woulda put some timing in the motor. we took out a full degree per psi and i puyt out 295 no sweat on 8psi. . after the dnyo i ran 11psi on stock internals with open dp , i can tell you now it was prob at least 330 to the wheels or so
SwiftTypeR
Apr 27, 2002 05:02 AM
