Where does the o2 sensor hook up? HELP?!?PROS-feel free to help...
On a CRX-mpfi w/ a ZC-where does the white wire go? Also another question...check here: https://honda-tech.com/zerothread?id=614231
Thanks to all who can help.....
From the o2 sensor it goes to the wire loom..and past the firewall into the ECU.
just like a stock set up..
O2 sensor goes on the down pipe of your DC header... about 3 inches from the CAT..
Someone told me this black wire is the connection- https://honda-tech.com/zerothread?id=614231
?!?-Please lmk if you have a pic of the routing of the o2..thnx
all in the first picture..
that green and yellow wire you have look like your reverse light switch..
The clear (female) and black (male) connector you have pictured..that has a one wire connection is your O2 sensor plug....
in the second and third pic you have, is all AC and rad fan switch stuff..
HXMan
Apr 26, 2002 08:13 AM
