B16a problems
Old Sep 11, 2003 | 09:39 AM
ORcivicsi's Avatar
Default B16a problems
I have a 99 b16a2. With i/h/e, fuel rail, fuel pressure, fuel filter, fuel pump, msd everything, field vafc, no cat, plus more. My problem is that my car is running very rich. I will be driving and once in a while it will stall out of nowhere. Then it starts again but it will stall if rpm drops below 2500. I think it is a faulty o2 sensor i have also been told that my fuel pressure regulator could be bad. But it is a new regulator.
Would an o2 sensor problem cause this mess?
(ALSO my check engine light is on from not running a cat. I think)
Old Sep 11, 2003 | 09:50 AM
976's Avatar
976
New User
Default Re: B16a problems (ORcivicsi)
Verify the CEL (Check engine light) number...
This will elimanate trouble shooting...
Old Sep 11, 2003 | 09:57 AM
Audi RS4's Avatar
Lover
Default Re: B16a problems (976)
http://tech.hybridgarage.com/tech/codes.html
Old Sep 11, 2003 | 02:33 PM
ORcivicsi's Avatar
Default Re: B16a problems (AK1200)
I have allready verified that it is the secondary o2 sensor, but it saying that because i have not catlytic converter. I just want to know if these are the symptoms of an oxygen sensor.
Old Sep 11, 2003 | 02:53 PM
HondaMan73's Avatar
A secondary O2 sensor fatilure should not cause the car to act that way as long as the primary o2 sensor is still functioning properly.
Old Sep 11, 2003 | 03:18 PM
ORcivicsi's Avatar
Default Re: B16a problems (HondaMan73)
Has anyone ever heard or know what causes my car to do this.
Old Sep 12, 2003 | 06:22 AM
Tachibana's Avatar
Sounds like the fuel map is off. (Might be the Fuel/Air controller)
Any error codes? (Aside from no O2 sensor)
Old Sep 12, 2003 | 09:35 AM
ORcivicsi's Avatar
Default Re: B16a problems (Tachibana)
No oher codes than secondary o2 sensor. I have been told that it might be the fuel map. Could this be caused by my vtec controller.
shawnh55
Sep 12, 2012 05:11 PM
eskimo10
Jul 21, 2009 07:45 PM
jarrYd
Mar 16, 2007 05:27 PM
Perfectionist
Oct 8, 2006 02:00 PM
X2BOARD
Jun 20, 2002 12:21 PM
