How much caster should I dial in?
Old Sep 11, 2003 | 09:23 AM
Jason C SBB's Avatar
Default How much caster should I dial in?
.. with the SPC caster/camber arms?
Setup:
'97 2-door
H&R OE sport springs (1/2" lower, ~40% stiffer)
Koni yellows
ST sways on order
ES100 tires
Looking for Superpro bushings
Goals: (in this order)
Fun to drive on twisties
Quicker turn-in
Decent trip
Neutral handling (i.e. I hate understeer)
A wee bit of throttle lift oversteer
TIA
Old Sep 11, 2003 | 12:23 PM
WuWarrior's Avatar
Default Re: How much caster should I dial in? (Jason C SBB)
Caster wont really affect the handling much at all.
2-3 degrees negative camber in the front is great for handling. I wouldn't go higher than that unless it's a race-only car.
To get rid of some understeer, the rear sway bar is very important. Bigger is better.
jaygood2go
May 23, 2013 01:43 PM
aka
Suspension & Brakes
May 19, 2007 07:03 PM
rockdude14
11
Mar 2, 2006 12:26 PM
Jason C SBB
Sep 13, 2003 12:39 PM
SpoonFed
Apr 3, 2002 03:10 PM
