torque specs
Old Sep 11, 2003 | 07:23 AM
jdmlsvtecrx's Avatar
Default torque specs
need to know torque specs from helms, 90 up integra preferably 94 and up. b18b, main cap torque and sequence and cam cap torque and sequence for vtec head. thanks
Old Sep 11, 2003 | 08:38 AM
Kataku2K3's Avatar
Default Re: torque specs (jdmlsvtecrx)
For the mains, start from the inside and work out... The first step I do is 22 ft/lbs., the second is 56 ft/lbs.
It will look something like this...
9 5 1 3 7
10 6 2 4 8 <---- Sorry for the shitty quality
And lastly on the cam caps... The 8mm bolts (ones with the 12mm head) will be torqued to 19 ft/lbs. and 8 ft/lbs. for the 6mm (10mm head) bolts on the end caps...
The sequence is very much the same tho I do IN and EX at the same time...
IN
25 17 9 1 5 13 21
26 18 10 2 6 14 22
EX
27 19 11 3 7 15 23
28 20 12 4 8 16 24
(in italics you'll see the 6mm bolts)
Old Sep 11, 2003 | 09:48 AM
is that helms specs, and thanks for the info, lost my manual. sick of borrowing other peoples
ivey_usmc
Aug 14, 2011 10:58 AM
slomofo
Honda Civic (2001 - 2005)
Aug 6, 2010 06:11 PM
peep
Jun 6, 2009 08:47 AM
boosted k20
Sep 20, 2004 10:32 PM
