cam cap specs?
Old Jun 5, 2009 | 10:15 PM
peep's Avatar
Default cam cap specs?
done a thousand searches. even got a manual. still can't get a positive answer on what the damn torque specs are for the camshaft caps. Are they7.2? please help. short simple answer will do.
Old Jun 5, 2009 | 10:46 PM
InvaderTrax's Avatar
Default Re: cam cap specs?
7lbs. I found that the click type torque wrench can not reliably read this because of the low torque setting and the squishyness of the aluminum. Personally, I figured out how to just do it by feel, like spark plugs
Old Jun 5, 2009 | 10:49 PM
steveo135's Avatar
cheap craftsman beam type torque wrence ftw
Old Jun 5, 2009 | 11:00 PM
KWayRacing's Avatar
A nice inch/pound torque wrench work great for the low torque values in the head. For a B16a2 the specs are the center 10 bolts are 20ft/lb and the 2 on each end are 7.2ft/lb. 12in/lb=1ft/lb.
Old Jun 6, 2009 | 08:29 AM
peep's Avatar
ya i'm using an inch pound wrench,and a conversion calculator. i miss read the instructions and did it for the GSR which was way higher i guess because i snapped a few 10mm bolts. now i have to tap them out of the head. so go 7 all around then?
Old Jun 6, 2009 | 08:47 AM
peep's Avatar
also, does anyone know why my cams will only rotate 180 degrees when i tighten down my caps?
slomofo
Honda Civic (2001 - 2005)
Aug 6, 2010 06:11 PM
Civic483973
Jun 21, 2010 11:33 AM
crxss outhe eyes
Jan 24, 2007 04:31 PM
jdmlsvtecrx
Sep 11, 2003 09:48 AM
DOHCtorTHRUST
Nov 8, 2002 07:43 AM
