hey , i still got a prob , with my cooling fan ????????
hey im the dude who had a prob with the 95 civic cooling fan , so heres the deal
my fan aint workin , the fan motor , fuse , and relay are all good , so i took a couple of you guys advise and i used a paperclip to jump the switch and my fan worked ........ so fifty bucks later i got the cooling fan switch , put it in changed my coolant , and now the damn thing dont work still ....... i even let the car warm up for like an hour it never kicked on , so does anyone have any other advise ????????
thanks
thanks
Did you replace your thermostat?
I am not sure, but think at idle, coolent might just keep your engine cold enough for a duration of maybe 30 minutes, but not an hour as you said.
If it is your switch I would recommend a proformance switch and thermostat, such as Mugen. Keeps your engine a lot cooler.
Hey. I had this problem with an 88 accord. First of all. When you replace the fan switch in the radiator make sure you use a honda switch! I used a NAPA switch for mine and it didn't work. Even though the NAPA switch was for my accord it was made to operate in larger temperature ranges so it can fit a wide variety of cars and not just the accord. I then bought a honda switch and the damn thing worked fine. The Honda switch is even cheaper then the NAPA one was. And while you're at it make sure you change the thermostat!
