degreeing a crower cam?????
Old Sep 10, 2003 | 10:46 PM
robtec's Avatar
Default degreeing a crower cam?????
if using "lobe center" method of degreeing, cam should be installed on an intake centerline of: 109
what the hell does this mean???
help, car not running well when the cam is installed
(note that the head is milled .060) does this mess up the cam timing or something??
Old Sep 11, 2003 | 06:55 AM
IN VTEC's Avatar
Default Re: degreeing a crower cam????? (robtec)
.060" off the deck(s) puts the cam timing at 5 degrees retarded.
You can find general info on lobe centerline cam degreeing on the Comp Cams website. You'll need a Cam Degreeing Kit pieced together by Comp Cams or the less expensive, but functionally identical one by Summit Racing.
Is the engine DOHC or SOHC?
Old Sep 11, 2003 | 09:37 AM
3gdude's Avatar
De-greeing cams is very technical to a beginner. Find someone who knows how to help you. 109 centerline on an intake cam means that the cam reaches max lift 109 degrees after TDC. On the exhaust, its number of degrees from max lift to TDC. You have to have a dial indicator and a degree wheel. Cutting .060" off the head will retard the cams about 2 degrees at the cam gear/ 4 degrees at the crank....as long as you dont change the thickness of the head gasket...3gdude
Old Sep 11, 2003 | 09:53 AM
IN VTEC's Avatar
Default Re: degreeing a crower cam????? (3gdude)
I thought the general rule of thumb for decking and cam timing changes was:
for every .012" you mill off the decks, you retard the cam timing by 1 degree.
No?
Old Sep 11, 2003 | 12:43 PM
robtec's Avatar
Default Re: degreeing a crower cam????? (IN VTEC)
thans a lot. i will retard the sproket 5 degrees. also what is the optimal ignition timing setting for a d16z6 with the cam and i/h/e and pulleys
Old Sep 11, 2003 | 05:55 PM
robtec's Avatar
using the info you people provided, i retard the cam timing 5 degrees and the car runs fine. now all i have to do is to go to a dyno and fine tune it
thans a lot
Old Sep 11, 2003 | 07:18 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3gdude &raquo;</TD></TR><TR><TD CLASS="quote">Cutting .060" off the head will retard the cams about 2 degrees at the cam gear/ 4 degrees at the crank....as long as you dont change the thickness of the head gasket...3gdude </TD></TR></TABLE>
true, for B-series cam gears - depends on the diameter of the gear - for instance Integra D16A1 has larger cam gears and would be 1 degree at about .040" cut
Old Sep 11, 2003 | 10:12 PM
robtec's Avatar
Default Re: degreeing a crower cam????? (jlicrx)
the d16a1 have two cams and the d16z6 have 1. i am asking about the z6
Old Sep 21, 2003 | 05:45 PM
robtec's Avatar
Default dyno tested today
tested the car on the dyno and it makes 138 hp to the wheels.only one run not tuned, cam timing at 0 degrees.ignition timing set at the stock setting.
sayanything
Dec 21, 2010 06:36 PM
250r king
Mar 13, 2010 10:32 AM
DrGrEeNtHuMb
Jul 29, 2009 01:08 PM
93b20z
Oct 11, 2006 07:28 PM
rough_draft
Mar 26, 2005 05:32 PM
