what's wrong with my car need help quick
Old Sep 10, 2003 | 09:24 PM
viet4gvtec's Avatar
Default what's wrong with my car need help quick
just done installed turbo for my 93vtec lude 6psi. Car pull real hard but power is not smooth(some time in 3rd gear,2 and 4) just sometime . i feel power gain at 3400 rpm then drop around 4400rpm after that it pull all the way to redline
what cause it?? and how can i fix it??
can it be the spark plug? they put in some champion (spark plug)****
can you tell me which plug is best for h22 turbo
thanks
Old Sep 10, 2003 | 10:07 PM
safe driver's Avatar
need more info.
what's your setup?
fuel management?
timing control?
Old Sep 10, 2003 | 10:09 PM
Ri5e's Avatar
Default Re: (safe driver)
How did you gap the plugs?
Old Sep 10, 2003 | 10:13 PM
viet4gvtec's Avatar
93vtec lude
garret t3/4, custom piping intercooler,vortech fmu, walbro fuel pum, tial wastgate
missing link was installed
only 6psi
Old Sep 10, 2003 | 10:25 PM
viet4gvtec's Avatar
Default Re: (Tein Man)
don't even know my mechanic put them in
Old Sep 10, 2003 | 10:45 PM
what trim turbo?
what fmu disk? probably 12:1 i bet..
what size dp, exhaust? with or with catalytic converter?
the type sparkplugs doesn't make that big of a difference unless they're gapped wayy off. heck, i'm using some generic autolite copper plugs in the stock heatrange right now.
just to be safe... you should stop driving in boost. you'll need to put your car on the dyno (or get a wbo2 sensor setup) to see where A/R ratio is at... before you blow your engine.
94_SI_CIVIC_TURBO
26
Aug 6, 2007 07:21 PM
Pete_SI
Jun 18, 2005 08:04 PM
Gs-R_turbo
Dec 6, 2004 08:16 AM
nato76
Apr 16, 2004 12:52 PM
InTeGrA B18b1
May 11, 2003 12:26 PM
