hard to get into gear
Old Sep 10, 2003 | 08:29 PM
EFing8's Avatar
Default hard to get into gear
it is very hard to get my tranny to go into first and second gear, the clutch is also slipping, would it be realated to the clutch or is it the tranny? it goes it, but it is hard. On another note, i have to push the clutch as hard as i can to the floor in order to start the car (clutch safety switch i guess) i have tried adjusting the cable but it seems to be as tight as it will go.
Modified by EFing8 at 9:48 PM 9/10/2003
Old Sep 11, 2003 | 01:52 PM
EFing8's Avatar
hard to get into all gears actually. ttt
Old Sep 11, 2003 | 03:10 PM
redrex's Avatar
Default Re: (EFing8)
i had the same problem and the op said my clutch was comin part whatever that means so i got a centerforce clutch a few days ago and havent had a problem since
Old Sep 11, 2003 | 03:39 PM
EFing8's Avatar
i had a feeling that it is the clutch, replacing it on sunday so we will see what happens there. i hate changing clutches.
Old Sep 11, 2003 | 05:41 PM
Steve90HB's Avatar
keep us updated, mine is having a hard time too... mainly first and second, does anyone know if honda has some safety feature that just won't let you go to first without being at pretty much a complete stop? I got a manual to CONTROL my tranny, but this POS won't let me
Old Sep 11, 2003 | 05:59 PM
Turbo Powa's Avatar
Default Re: (Steve90HB)
BUMP! I'm having a problem going into first sometimes too! I need to let off the clutch and press it again. Is that my synchro going or a bushing or a loose shift linkage?
Old Sep 11, 2003 | 06:32 PM
91civicEX's Avatar
if u give it a rev to about 3-4k it should go into first at about 15-20 mph
Old Sep 11, 2003 | 06:38 PM
Steve90HB's Avatar
Default Re: (91civicLX)
mine won't let me go into first no matter what unless I'm going under 5 mph... same goes to 2nd when going over 20 - if I'm in 3rd+ (I can't downshift around turns or anything unless I'm going really slow)
it's frustrating... and it grinds bad if I force it in there
Old Sep 11, 2003 | 07:05 PM
EFing8's Avatar
mine has a very hard time going in even at a stop! it is driving me nuts.
Old Sep 11, 2003 | 07:29 PM
Turbo Powa's Avatar
ditto!!
Old Sep 14, 2003 | 10:00 PM
Steve90HB's Avatar
Default Re: (Panda EK)
TOP, so is it the clutch or what? I did notice some slipping in my clutch - especially at high RPMs... I shift into 3rd gear and my RPMs slowly drop, then start to climb again
Old Sep 15, 2003 | 08:38 AM
spooned out's Avatar
i don't think its the clutch, i have a new exedy clutch in mine and sometimes i have to struggle with it to go into first, i even baught a new integ clutch cable didn't make that much of a diff, i'm thinking its my shift linkage replacing that sometime soon if that don't work cable trannies just suck, recently changed my s1 tranny for the a1 because of bad synchros, but mess with the *** to adjust the tension that helps
Old Sep 15, 2003 | 08:54 AM
Lo-Buck EF's Avatar
Default Re: (spooned out)
hard shifting is either the clutch or the forks. if the shift effort is higher than normal, then the shift forks are bent. if u force the car into gear, u WILL bend the shift forks. if the car just soesnt want to go into gear, then try adjusting the clutch. i know with my new trans and stock clutch the car doesnt want to go into first while rolling. but i can rev-match it in no problem. the first gear thing is how the trans is supposed to be IIRC.
Old Sep 15, 2003 | 03:48 PM
EF8_SiR's Avatar
Default Re:
double clutch and rev match.
I had problems too b4 but changed my release bearing and put in heavier tranny oil and it's gotten better.
Old Sep 23, 2003 | 02:49 PM
EFing8's Avatar
changed pedal box, it had a crack in it, so when i tried to clutch it wasn't really pulling the cable to good, just flexing the metal box the pedals bolt to. damnit 3x
Old Sep 23, 2003 | 06:24 PM
youngwon22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve90HB &raquo;</TD></TR><TR><TD CLASS="quote">keep us updated, mine is having a hard time too... mainly first and second, does anyone know if honda has some safety feature that just won't let you go to first without being at pretty much a complete stop? I got a manual to CONTROL my tranny, but this POS won't let me</TD></TR></TABLE>
this is my situation, but try shifting down to 1st in its "zone" example, you could probably go up to 35mph or whatever, so when you get to 30 or somethin then shiftdown it should work. If you listen closely, you can hear gears rubbing on something when you try to shift. Anyone know if it's suppose to make that sound?
TruenoMike14
Oct 22, 2013 11:36 PM
Dc295kid
Dec 19, 2009 07:05 AM
slowdaintegra
Dec 21, 2005 01:31 PM
shhh151
Sep 8, 2005 05:42 PM
green98civic
13
Jun 28, 2003 10:13 AM
