89 civic 4 door swap ?
Old Sep 10, 2003 | 07:27 PM
turbo sol's Avatar
Default 89 civic 4 door swap ?
a friend of mine has a 4 door civic, and knows nothing about them. I have never seen this civic but he blew up the engine today because of no oil. it is an automatic
I have a d16a6 swap minus the tranny, and injectors.
can i drop in the d16a6 into his car and use his intake manifold, ecu, tranny, ect. (everything except the head and block) with out any problems?
I have done a z6 obd1 swap in my crx, but i didnt know if i would run into any problems with the d16a6 in a auto with dpfi (< I assume it is dpfi, did they make a mpfi 4 door?)
what do you guys think I should charge for labor?
thanks for helping me make a few dollars for my crx.
Old Sep 10, 2003 | 07:49 PM
dingusjt's Avatar
Default Re: 89 civic 4 door swap ? (turbo sol)
first off find out what model 4 door he has...if its DX or LX then you can't use his manifold etc cause its DPFI...however if he has an EX then you are in luck because his stock engine is a d16a6....just easy switchover.
Old Sep 10, 2003 | 07:54 PM
blah13's Avatar
Default Re: 89 civic 4 door swap ? (dingusjt)
The d16a6 will be a direct bolt in. If its a dx or lx you will need...
1. MPFI Injector resistor box.
2. Fuel line from filter to rail.
3. MPFI auto ecu, 88-91 civic ex or 88-89 teg(rich but works)
4. Extra wire for the extra 2 injectors.
Basically your doing an mpfi swap just with an auto, if it is an EX then you just swap the engines and your good to go. I'd charge 200-300ish since its your buddy and the 2 of you should be able to get it done in a day or 2, assuming your using your own tools etc.
Old Sep 11, 2003 | 04:17 AM
turbo sol's Avatar
Default Re: 89 civic 4 door swap ? (blah13)
i dont have the right ecu for a mpfi auto,
so i was going to make it a DPFI d16a6, wont that work? it wont be the most performance savy, but he needs a car that runs.
Old Sep 11, 2003 | 05:33 AM
turbo sol's Avatar
oh another question.
will a d15b exhaust manifold bolt up to a d16? i know the intakes swap out but i dont know about the exhaust.
Old Sep 11, 2003 | 07:07 AM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo sol &raquo;</TD></TR><TR><TD CLASS="quote">oh another question.
will a d15b exhaust manifold bolt up to a d16? i know the intakes swap out but i dont know about the exhaust.</TD></TR></TABLE>
Yes.
Old Sep 11, 2003 | 07:39 AM
turbo sol's Avatar
Default Re: 89 civic 4 door swap ? (4drEF)
no one has any thoughts abotu goign to the DPFI on the d15?
Old Sep 11, 2003 | 07:45 AM
turbo sol's Avatar
what shoudl i do about fuel? the d16a6 uses more than a d15, so will a d15 ecu be enough or not?
Old Sep 13, 2003 | 12:24 PM
Limited S.L.I.P.'s Avatar
Doing the mini me to my 4 door 1990 EX this coming week! woo-hoo! wish me luck, and I'll let you all know how it goes! d16z6 head, exedy clutch, springs all in on Weds. hopefully my gasket, timing belt and studs are here on time!
Old Sep 13, 2003 | 12:30 PM
dingusjt's Avatar
Default Re: 89 civic 4 door swap ? (Limited S.L.I.P.)
IS IT EX OR DX OR LX???
answer that and you may get some answers!!! by the way dpfi d15 is stock so i don't know why you are asking about it?
SprayinCX
Dec 2, 2005 05:26 AM
benh
Apr 25, 2005 04:34 PM
kuckimonster2
Sep 14, 2004 07:18 AM
