CEL CODES 22 43 ON H22 WITH P28 !!! NO VTEC
Old Sep 10, 2003 | 07:10 PM
H22AJSPEC's Avatar
Default CEL CODES 22 43 ON H22 WITH P28 !!! NO VTEC
I have an h22 in an accord new engine >I did have an h22 before in this car but had a better one built. I have done all the trouble shooting I can find any were on the web and nothing. My accord throws codes only when i drive it hard like around 7500 rpms .My autometer air fuel reads normal and car runs great but I have no vtec and these check engine lights 22 and 43 .Also my vtec solinoid does open and is in good working order but still no vtec.
Old Sep 10, 2003 | 08:18 PM
poison's Avatar
Default Re: CEL CODES 22 43 ON H22 WITH P28 !!! NO VTEC (H22AJSPEC)
Is the p28 stock? code 43 shouldn't be going unless it could be a stock chip on the p28 ecu from running lean.
as for the code 22, that is the vtec pressure switch. I would grab a digital multimeter and verify your wires (ground to the thermostat housing, and the Blu/Blk wire going to the D6 pinout), as well as make sure the H22 has oil level full.
If all proves just fine, then I would recommend replacing the oil pressure switch.
HTH.
Old Sep 10, 2003 | 08:33 PM
H22AJSPEC's Avatar
Default Re: CEL CODES 22 43 ON H22 WITH P28 !!! NO VTEC (poison)
Did not have this problem with last engine and the pressure switch has been changed and all wiring checked out.
goinfast
Engine Management and Tuning
Aug 5, 2015 11:45 AM
The Destroyer
Apr 8, 2007 07:18 PM
Novtecdohc
Nov 15, 2006 09:16 PM
optikal_blitz
Jul 22, 2005 07:50 AM
wutupnut
Apr 15, 2005 06:34 PM
