M&H street slicks
M&H sells a 235/60/15 dot street slick and I was curious if it would be too big. I know the width might not be to big, but the height might rub the fender. Any one know or have any experiece with something this size? BTW these are for a 400+hp integra.
Just test fit them if they rub the fender raise the car up a little
I had 215/55/15's on my car before i got rid of them and my car is freakin dumped i mean can't put a ciggerette pack on its side under the car so i think you should be ok 60's arn't that much bigger than 55's.
also what width wheel are you running?
I had 215/55/15's on my car before i got rid of them and my car is freakin dumped i mean can't put a ciggerette pack on its side under the car so i think you should be ok 60's arn't that much bigger than 55's.also what width wheel are you running?
each sidewall is .45" taller on the 235/60/15 (2.775" each) versus the 215/55/15 (2.325")
that's a noticable difference.
m&h's site (www.intercotire.com) says you can run the 235/60/15 on a 6.5" wide wheel.
the huge sidewall allows you to run a narrower wheel.
7" wheel will give you a slightly bigger contact patch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlicksMH »</TD></TR><TR><TD CLASS="quote">235/60/15 </TD></TR></TABLE>
what is the overall tire diameter??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jinxproof99 »</TD></TR><TR><TD CLASS="quote">
what is the overall tire diameter?? </TD></TR></TABLE>
It's actually 25.4"
It's actually 25.4"
Hi Jinxproof99,
Here is the size of the P235/60-15 DOT --
Tread width = 7.5"
Section Width = 9.8"
Dia. = 25.4"
Circ. = 80"
Rim Size = 6.5"
Thanks for listening
John@M&H
Modified by SlicksMH at 12:34 AM 9/12/2003
Tread width = 7.5"
Dia. = 25.4"
Circ. = 80"
Rim Size = 6.5"
John@M&HModified by SlicksMH at 12:34 AM 9/12/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlicksMH »</TD></TR><TR><TD CLASS="quote">Hi Jinxproof99,
Tread width = 7.5"
Dia. = 25.4"
Circ. = 80"
Riz Size = 6.5"
John@M&H</TD></TR></TABLE>
25.4 diameter will fit no problem on an integra, civic, or hatch(92 and up) with coilovers. on a 15" rim that is one hell of a sidewall and if they are sticky, they would make an AWSOME street race tire for imports.........not that i would condone that type of behavior
way to go m&h.
Tread width = 7.5"
Dia. = 25.4"
Circ. = 80"
Riz Size = 6.5"
John@M&H</TD></TR></TABLE>25.4 diameter will fit no problem on an integra, civic, or hatch(92 and up) with coilovers. on a 15" rim that is one hell of a sidewall and if they are sticky, they would make an AWSOME street race tire for imports.........not that i would condone that type of behavior
way to go m&h.
What do you think about this one (jinxproof99) It's called the DOT P205/60-13 and this is a new Tiger coming to us.
Tread Width = 7.5"
Section Width = 8.8
Dia. = 22.8
Cir. = 71.6
Rim Size. = 6.0"
This is a Bia's ply type, and it will bite harder then the radial.
John@M&H
Modified by SlicksMH at 12:49 AM 9/12/2003
Tread Width = 7.5"
Section Width = 8.8
Dia. = 22.8
Cir. = 71.6
Rim Size. = 6.0"
John@M&H Modified by SlicksMH at 12:49 AM 9/12/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlicksMH »</TD></TR><TR><TD CLASS="quote">What do you think about this one (jinxproof99) It's called the DOT P205/60-13 and this is a new Tiger coming to us.
Tread Width = 7.5"
Section Width = 8.8
Dia. = 22.8
Cir. = 71.6
Rim Size. = 6.0"
John@M&H </TD></TR></TABLE>
looks like a bfg killer to me
Tread Width = 7.5"
Section Width = 8.8
Dia. = 22.8
Cir. = 71.6
Rim Size. = 6.0"
John@M&H </TD></TR></TABLE>looks like a bfg killer to me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00n'd Supra »</TD></TR><TR><TD CLASS="quote">
looks like a bfg killer to me</TD></TR></TABLE>
O Sorry and It has the M&H racing compound.
John@M&H
John@M&H
the 13's would/should be perfect for the allmotor guys for an et street type of tire. what is the compound compared to?? do you have any pics of the tread pattern(or hopefully, the lack there of
Go to mandhtires.com and go to racing tires and click on the dot and check out the P235/60-15 they told me It's going to be that tread pattern. John@M&H
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR831 »</TD></TR><TR><TD CLASS="quote">John,
no 14" street slick?
Barney</TD></TR></TABLE>
What size 14" in a Dot do you want? and what do you think about that 13" in the Dot. John@M&H
What size 14" in a Dot do you want? and what do you think about that 13" in the Dot. John@M&H</TD></TR></TABLE>
like a 225/50/14 or 205/55/14
i think 13's are too small for the street.....imo
I think a 14" tire in a 235/60 would be kind of cool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GraphiteAccord »</TD></TR><TR><TD CLASS="quote">
I think a 14" tire in a 235/60 would be kind of cool. </TD></TR></TABLE>
Nevermind, i went to your site, and see that you guys have one!
Hi (no2psi) now that is a good Question, If you run the M&H Dot for a daily driver now you take it this is a M&H Racing Compound, you will only get 4-5000 miles out of them, but if you only use them to go to the drags and back home they can go 3 to 4 years as long as you take care them. Now how do you do that you ask, just like anyother racing tire, keep the out of the direct sun light, keep them out of the cold, take them back off the race car when not in use and cover them up.
Thank You for listening Dave.
John@M&H
John@M&H
will this size tire fit in a crx/civic?
