f22a block with a 93 si prelude head
Old Sep 10, 2003 | 02:50 PM
hotaccord's Avatar
Default f22a block with a 93 si prelude head
does anybody know if you can take a 1991 honda accord f22 block and put a DOHC non-vtec prelude head on it. like a 93 si head of that year of prelude?
Old Sep 10, 2003 | 04:38 PM
f22a's Avatar
not without a good bit of work. the bores are different.
Old Sep 10, 2003 | 04:55 PM
hotaccord's Avatar
Default Re: (f22a)
are the bores that much differnt that i couldn't put it on with out doing anything to the stroke or bore size
Old Sep 11, 2003 | 08:09 AM
Gennady's Avatar
New User
Default Re: (hotaccord)
http://www.accordinglydone.com...=2239
Old Sep 11, 2003 | 08:19 AM
f22a's Avatar
Default Re: (Wont be beat)
2mm different. the head has to be welded.
Old Sep 11, 2003 | 06:57 PM
hotaccord's Avatar
have you seen it done before or have you did. is it even worth putting time and money into i already have the head and extra parts for it.
Old Sep 12, 2003 | 06:40 AM
GimpyAccord's Avatar
considering people swap heads around on the B series with >2mm bore size differences ... thats a non issue.
Old Sep 12, 2003 | 06:54 AM
carolinaACCORD's Avatar
Default Re: (GimpyAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GimpyAccord &raquo;</TD></TR><TR><TD CLASS="quote">considering people swap heads around on the B series with &gt;2mm bore size differences ... thats a non issue.</TD></TR></TABLE>
Right on Gimpster!
This is a doable project. I'm not saying it wont take some work, though.
Be an innovator, not a imitater.
Old Sep 12, 2003 | 01:11 PM
v4lu3s's Avatar
RTFM
i know a shop that has done it...with the cost of parts (them supplying the head) and labor....it makes more sense to jsut save a few hundred more, and buy an h22a then put it in yourself.
Old Sep 14, 2003 | 06:27 PM
hotaccord's Avatar
Default Re: (v4lu3s)
well when i asked the question i was in the middle of doing the swap. i finished it this weekend and i ended up only having around 500 or 600 dollars in it was a little less than a h22a but i wanted to do this because i have never seen it done and i wanted to do something different i'm getting it dyno tested some time this week to see how much whp gain i got from it but so far the engine runs great and i can deffently tell that it gain alot from the stock motor
93h23torque
Sep 13, 2006 06:41 PM
nippi4513
Jun 27, 2005 07:49 AM
Civic2Fast
Mar 22, 2005 11:22 AM
civic4218
Sep 11, 2003 04:30 PM
Lowlude
Apr 22, 2002 02:32 PM
