? about factory. tach. & VAFC
Old Sep 10, 2003 | 02:07 PM
HYREV2NR's Avatar
Default ? about factory. tach. & VAFC
Ever since I got my VAFC I noticed the factory tach reads about 200-300 rpm's higher than the tach on the VAFC. For instance; holdin the engine steady @ say 4350 rpm's, the VAFC reads roughly 4100 rpm's. Which 1 is more acurate?
Old Sep 10, 2003 | 02:11 PM
TypeR 599's Avatar
Default Re: ? about factory. tach. & VAFC (HYREV2NR)
VAFC. nearly all ITR stock tachs are off
Old Sep 10, 2003 | 02:15 PM
Fac3Man's Avatar
Factory tach is off.
I dynoed my car the other week and was letting off at an indicated 8800rpm, on the print out the graph stopped at 8500rpm.
Old Sep 10, 2003 | 03:36 PM
GZR4DR's Avatar
Default Re: ? about factory. tach. & VAFC (Fac3Man)
VAFC on my car read the same as the dyno machine was reading. Tach is a couple hundred rpm's higher on my car. Its normal on all Honda's from what I've seen.
Old Sep 10, 2003 | 04:08 PM
type r 01-1063's Avatar
What about Spoon's tachometer on the gauge cluster?
Old Sep 10, 2003 | 04:27 PM
uNF$@#!'s Avatar
Default Re: ? about factory. tach. & VAFC (type r 01-1063)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type r 01-1063 &raquo;</TD></TR><TR><TD CLASS="quote">What about Spoon's tachometer on the gauge cluster? </TD></TR></TABLE>
considering they use the same kind of loaded electronic coil, i would assume so.
Old Sep 10, 2003 | 04:31 PM
BlueR's Avatar
Default Re: ? about factory. tach. & VAFC (Soup ****)
soup, lets test the spoon tach this weekend
Old Sep 11, 2003 | 06:21 PM
B2FiNiTY's Avatar
Default Re: ? about factory. tach. & VAFC (BlueR)
Spoon tach is right on
hatchback_al
Jul 24, 2004 12:43 PM
LeftCorner
Jan 6, 2003 03:54 PM
RAB
Dec 8, 2002 09:57 PM
mntdewred
Jul 26, 2002 09:28 AM
BoostedGSRBubble
Jun 19, 2002 08:38 PM
