F20B Oil pan Same as H22?
Old Sep 10, 2003 | 01:03 PM
Magnaflow's Avatar
Default F20B Oil pan Same as H22?
Does anyone know if the F20B motor uses the same oil pan as does the H22?
Old Sep 10, 2003 | 03:45 PM
JDogg's Avatar
Default Re: F20B Oil pan Same as H22? (Magnaflow)
i havent looked at it that close but at first glance they look the same.. if you can wait till next week i can tell you for sure...
im gona assume you have a f20b? is it a 5spd motor? if it is can you measure the throttle body for me? i got a auto motor and im trying to figure out the differences. my tb is about the same size as a f22a or d16y8
Old Sep 10, 2003 | 09:36 PM
fizzbob7's Avatar
Default Re: F20B Oil pan Same as H22? (JDogg)
i was also wondering why the autos make 20 less hp than the manuals on the F20B setup....i know cams are usually different in these circumstances....add lower end power but lose top end power....i dunno
Old Sep 11, 2003 | 06:37 AM
Magnaflow's Avatar
I can measure mine, but mine is / was an Automatic. I am converting it to a 5 spd. with a manual tranny from a prelude. Do you guys know if I will need a different ECU because of the Auto-Manual conversion?
Old Sep 11, 2003 | 08:23 AM
93preludeh22's Avatar
yes, need new ecu
Old Sep 11, 2003 | 08:26 AM
Magnaflow's Avatar
Default Re: (93preludeh22)
Damn, Thats what I was afraid of... So I need an OBDII Prelude computer? That will work correct?
Old Sep 11, 2003 | 10:26 AM
JDogg's Avatar
Default Re: (Magnaflow)
the auto ecu should work.. you'll have a check engine light though.
Old Sep 11, 2003 | 10:42 AM
Magnaflow's Avatar
Default Re: (JDogg)
Hmmmmm sounds like I will need to search for an MIL eliminator then.
Old Sep 27, 2003 | 05:59 PM
Mighty Mintos's Avatar
the oil pans are different. if you replace the oil pan with an h22 you have to get the same h22 oil pick-up.
Old Mar 20, 2021 | 08:33 AM
94hawkster's Avatar
Magnaflowe: Do you still have the ECU for the F20B engine for automatic trans?
BoiTypeR
Sep 5, 2016 02:21 AM
BergRacing21
Jul 18, 2011 06:33 PM
Prudz_lude
Oct 20, 2009 10:18 AM
2000redsi
Jun 1, 2006 12:00 PM
