Best cams for my set-up?
Old Sep 10, 2003 | 12:57 PM
SadisticRacing's Avatar
Default Best cams for my set-up?
i want to take a poll to see which cams you guys think I should get for my set-up. I have a B16a with i/h/e, cam gears, 68mm tb, 75 dry shot, ACT stage 4 clutch and fuel rail and reg. I only drive it on the street about once a week so need some street ability but mostly drag. I put some choices pick one of those or add one i forgot thanks.
Old Sep 10, 2003 | 02:15 PM
dkim48's Avatar
Default Re: Best cams for my set-up? (SadisticRacing)
why not just get a bigger nozzle for a 100 shot? Cheaper
Old Sep 10, 2003 | 03:11 PM
Jared's Avatar
for an otherwise stock engine with i/h/e, the s2s2s and jun 3s are way over cam for that engine. Check out the EF-1 M20s.
Old Sep 10, 2003 | 03:45 PM
Default Re: Best cams for my set-up? (dkim48)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 &raquo;</TD></TR><TR><TD CLASS="quote">why not just get a bigger nozzle for a 100 shot? Cheaper</TD></TR></TABLE>
I plan on switching from a dry 75-shot Zex system to a NX direct port 80-shot but still want to get cams
Old Sep 10, 2003 | 03:46 PM
Default Re: Best cams for my set-up? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">Check out the EF-1 M20s.</TD></TR></TABLE>
Where can I get more info on these cams.
Old Sep 10, 2003 | 04:23 PM
Jared's Avatar
http://www.ef-1.com
Old Sep 11, 2003 | 01:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ef-1.com</TD></TR></TABLE>
Thanks
Old Sep 11, 2003 | 01:57 PM
SpoolnG2's Avatar
SKUNK2 = its a great cam for the money, and has a bad *** crossover!
Old Sep 11, 2003 | 07:02 PM
hybridEj6's Avatar
Default Re: Best cams for my set-up? (SpoolnG2)
i hope u plan on retarding the timing, the direct port is defintly a good idea, id get the cams and step it up to 100 shot with the direct port with slicks CTR cams
Old Sep 11, 2003 | 07:47 PM
Default Re: Best cams for my set-up? (hvacfunded)
my timing is already retarded 4 degrees with my 75-shot.
Icey112
Oct 20, 2004 08:38 AM
,Kazi
Apr 7, 2004 10:18 AM
swpdb16
Apr 3, 2004 12:08 PM
Midwestrider
May 1, 2002 10:19 PM
Midwestrider
May 1, 2002 07:07 PM
