higher rpm is inaccurate?
Old Sep 10, 2003 | 11:01 AM
HatchSteer's Avatar
Default higher rpm is inaccurate?
I've done a search and found nothing on this topic.
I've heard once that as the engine approaches a higher RPM, the tachometer reading becomes slightly inaccurate. I heard this is also the case for the speedometer (when hitting high speed, speedo is inaccurate). I was wondering how big is the inaccuracy difference? And what is the common cure? Will an aftermarket speedo and tacho do? Or is it always going to be inaccurate regardless?
thanks
Old Sep 10, 2003 | 11:33 AM
Padawan's Avatar
Darth ModerVader
Default Re: higher rpm is inaccurate? (Doom_Hatch)
Yes, both gauges become inaccurate in the upper ranges. Most aftermarket tachometers are more accurate than the stock units. As for the speedometer, I'm not sure why that would matter much anyway.
hondacrx2
14
Jul 27, 2011 04:40 PM
HBRIDER
Jul 4, 2008 03:03 PM
TypeSH
Jul 30, 2002 10:33 AM
mlancer1
Oct 16, 2001 06:20 AM
jayson roman
Jul 22, 2001 01:55 PM
