90 CIVIC SI seats in 90 CRX not working?!
its a CRX HF and the rails dont even unbolt in the same place on the SI seats! is there any way to make it work without modifying??? i wana be able to move the seats back tto my civic in a few months
I have 1990 CRX-Si seats in my 1991 STD. They don't bolt up. I had to weld some new brackets onto the stock Civic rails. They aren't perfect, but good enough.
I remember I did a search on here, and someone showed how he did it with bolt on brackets, I copied his design, but welded them.
It isn't easy, but I'm VERY glad I did it..
i'm pretty sure any year crx seat WILL NOT bolt right in to any year civic (and vice versa). to get the seats in there, you need to do some "custom" work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GIAMotorSports »</TD></TR><TR><TD CLASS="quote">Get some self tapping bolts and put them through the floor thats how I got my gs-r interior into my hatch</TD></TR></TABLE>
thats not a safe thing to do. the floor pan isnt strong enough to hold the seat to the car in the event of an impact
Yeah. In a 35 mph accident, you are creating approximately 60 times your normal weight in force on the seat.. I don't think self tappers are going to hold my 14,000 lb ***.. And might be a source for rust eventually, too.
This is not an area to half-***.
i read about the crx seats not fitting in the civic... what the hell everyone putting crx seats in a civic for?! my HF has some raggedy seats and my civic SI seats are pimp!. anyways ther is no solution to my problem???
i put 89 crx si seats in my 90 dx hatch;i adjusted the seat back and forth untill i realized that two of the bolts go right in,then i bent one of the rail ends down and drilled it out a little and it fit, the last one i had to do some cutting and welding to get it to fit,it wasnt to bad and they fit good.
FWIW, I put 91 Teg XSi seats into my 90 HF. Did not even come close, well, possibly 2 bolts! Required custom bracket modifications involving welding, machining and other mechanical work including cussin'. I have answered these threads before and my answer is the only seat that will 100% bolt in is the one that is in it.
HTH
chris
HTH
chris
Dammit...I've asked this question numerous times and never got an answer now I got more in someone else's thread than I ever have.
Dammit....I want crx seats in my dx
serious
Mar 27, 2003 07:02 AM
Kin
Mar 29, 2002 04:19 PM
