zc to si problem
Old Sep 9, 2003 | 11:10 PM
zexdrex's Avatar
Default zc to si problem
the cars a 90dx crx and i had swaped in a zc but things went bad and we put in a si motor we swaped the turbo off the zc and went to start the car but now it doesnt run right it has NO power and a really rough idle when not running it throws code 4 but as soon as its started code 4 goes away but 3 and 7 start please help
could it be the timing??? would that mess up the throttle and crank angle sensors??
Old Sep 10, 2003 | 05:26 AM
DJ_SaNdOz's Avatar
Default Re: zc to si problem (zexdrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zexdrex &raquo;</TD></TR><TR><TD CLASS="quote">the cars a 90dx crx and i had swaped in a zc but things went bad and we put in a si motor we swaped the turbo off the zc and went to start the car but now it doesnt run right it has NO power and a really rough idle when not running it throws code 4 but as soon as its started code 4 goes away but 3 and 7 start please help
could it be the timing??? would that mess up the throttle and crank angle sensors?? </TD></TR></TABLE>
did you rewire the dizzy plug correctly? If not, that's your problem
Old Sep 14, 2003 | 01:43 AM
zexdrex's Avatar
Default Re: zc to si problem (DJ_SaNdOz)
yeah i checked again, seems to be right - the wires went one for one theres 2 whites but it only starts one way
any other ideas??
Old Sep 14, 2003 | 10:25 AM
91civicEX's Avatar
firing order? check to see if all ur cylinders are firing by pulling injector plugs. if idle doesnt change when you pull a plug youll know that cyl isnt firing
Old Sep 14, 2003 | 03:54 PM
zexdrex's Avatar
Default Re: (91civicLX)
thanks ill try that
DumpdEJ6
10
Nov 18, 2012 07:56 AM
dohczcrex
Jun 10, 2007 07:20 AM
DEADLYACURACCY
Mar 9, 2006 04:57 PM
DJ_SaNdOz
11
May 28, 2003 08:34 PM
