Which wires to run?
Old Sep 9, 2003 | 09:41 PM
hondacivic4g's Avatar
Default Which wires to run?
Ok, i have a D15B, adding a D16Y7 head and swapping to mpfi. The distributor is SI. Should i run D16Y7 wires? Also should I run a D16Y7 timing belt?
Thanks-Jason
Old Sep 9, 2003 | 09:47 PM
4crx4me's Avatar
Default Re: Which wires to run? (hondacivic4g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacivic4g &raquo;</TD></TR><TR><TD CLASS="quote">Ok, i have a D15B, adding a D16Y7 head and swapping to mpfi. The distributor is SI. Should i run D16Y7 wires? Also should I run a D16Y7 timing belt?
Thanks-Jason</TD></TR></TABLE>
If I'm not mistaken, the D15 is OBD0 DPFI
And the Y7 is OBD2(?) VTEC MPFI
You'll have alot of wires to swap AND run and you need a conversion harness. And a new OBD1 dizzy.
HTH
Old Sep 9, 2003 | 09:54 PM
D16Y7 head is non-vtec and i'm running a D16Y8 intake manifold set up for a 88-91 CRX/Hatch.
Old Sep 10, 2003 | 06:25 PM
any one else?
derek18105
Nov 19, 2009 07:52 PM
Imsleeping
May 23, 2005 09:34 PM
hondacivic4g
Sep 10, 2003 06:25 PM
fearless_dsm
Jul 15, 2003 11:10 PM
