How low is -50mm -15mm front and rear?
Actually on the official Cusco website, it just says -50 and -15 without the MM part. It says -65 for the Zero 1 and 2's so does that mean they can only lower 2.6 inches?? Something doesn't seem right.
If you translate the top right part of the graph it says "ŽÔ‚’²®•immj" which roughly translate to english as "Height span of adjustable range (mm)" so the all the numbers on the two right most column are for the height.http://www.cusco.co.jp/03ad/cs_honda.html
