B16B Pistons in B18b
its possible... use b16b rods
edit: my bad... i misread. i was thinking of ctr crank in an LS block.
on me
Modified by allmtr at 3:30 PM 9/10/2003
on meModified by allmtr at 3:30 PM 9/10/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmtr son »</TD></TR><TR><TD CLASS="quote">its possible... use b16b rods</TD></TR></TABLE>
negative use the ls rods the b16b ones wont work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iHave2Cams »</TD></TR><TR><TD CLASS="quote">where can i pick up a set of shotpeened ls rods?
Have your machine shop shotpeen your rods. And, I'm sure you probably know this, but if you are planning on going turbo as it states in your sig, I would suggest against using PCT slugs.
Adam
Adam
Which other rods will work with the B16B Piston if it is going in a B18C bottom?
PS. I wish people could just keep quiet, if they don't know the answers. I and many other people are trying to learn and get correct infos on our build up. Allmtr son
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iHave2Cams »</TD></TR><TR><TD CLASS="quote">you would get about a 10.8:1 cr with b16a pistons and about 11.4:1 cr with b16b pistons</TD></TR></TABLE>
this is also not true. in a b18a or b18b which is the same bore and stroke. pr3 pistons will net you about 11-3-1 compresion.
p30 pistons are about 11-5-1
and b16b(CTR) will put you over 12-1 compression in your LS block.
usdm ITR pistons will set you around 11-1.
try to use the same LS rods that are on the crank your using. make sure to have everything ballanced.
and most of all use ARP rod bolts. 8mm size not the 9mm.
shot peeing is kind of like seeing a black cat walk in front of you. some people beleive in it,some dont. shot peeing only strengthens the rod 5% and its only on the outside, not completly. if you need to get crazy ,go for CRYO treating or buy new rods.
hope that helps you guys more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmtr »</TD></TR><TR><TD CLASS="quote">its possible... use b16b rods
on me
on me</TD></TR></TABLE>
If it's going in an LS you must you LS spec'd rods. Don't waste money on shotpeening. Instead just buy ARP rods bolts. CTR pistons will work fine with I think .192" shaved off each side. Taht number sticks out in my mind. Rocket correct me if i'm wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by letholone »</TD></TR><TR><TD CLASS="quote">
usdm ITR pistons will set you around 11-1.</TD></TR></TABLE>
And even this is not true. This would be close if you were using an VTEC head. Remember this is a pure LS motor. The combustion chamber volume on the Non VTEC heads is 45cc unlinke 42.70 PR3 and 41.60 P72
USDM B16's about 10.8:1, JDM B16's about 11:1, CTR about 11.4:1.
Again this is stock 81.00mm bore, stock headgasket, stock valves etc... Let's not get ahead of ourselves.
jdmbeegee
Sep 5, 2006 10:04 PM
RICE POLICE SIP
53
Jul 10, 2006 09:07 AM
hotimportcrx
10
Sep 6, 2005 10:39 PM
