window question:
Rip off the door panel and pry off the plastic covering the door, then put the window back in the frame, tighten it up and close it all back up.
I am pretty sure u will figure it out once u get the inner door panel off.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordOn18z »</TD></TR><TR><TD CLASS="quote">its a common on 94 and 95's</TD></TR></TABLE>
yup very common for the 94 & 95's. i had to replace both passenger and driver side window regulators
I just spent $189 for a new drivers side reg at the dealer
I needed to buy it the same day because a storm was comming so i had no time to wait.
But if i had more tim i could have got one off ebay new for $50.00
Im gonna go ahead & get a passanger side just in case so i have it.
.I needed to buy it the same day because a storm was comming so i had no time to wait.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lvbuckeye »</TD></TR><TR><TD CLASS="quote">94 Accord EX... widow fell out (i guess IN, really) how the hell do i get it re attached? </TD></TR></TABLE>
first... do what this guy says:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman »</TD></TR><TR><TD CLASS="quote">Rip off the door panel and pry off the plastic covering the door, then put the window back in the frame, tighten it up and close it all back up.
I am pretty sure u will figure it out once u get the inner door panel off.</TD></TR></TABLE>
if the regulator is broken and wont go back together, you will need to buy a new one. Check the junk yards or buy it from the dealer. I bought both passenger and driver side window regulators from the dealer and installed them with a friend.
what i found to be common is that a certain little plastic piece is what breaks. this little plastic piece is part of what keeps it together.
dynamo
Nov 18, 2003 11:43 PM
