ctr lsd into 00si trans
Old Sep 9, 2003 | 05:28 PM
tangb2023
Guest
Posts: n/a
Default ctr lsd into 00si trans
wondering how hard is the install for ctr or itr lsd to be swapped into 00 si trans.. anybody got a how to?? how long does it takes, 4 hrs?
thanks
Old Sep 9, 2003 | 06:00 PM
quik2kSi's Avatar
Default Re: ctr lsd into 00si trans (tangb2023)
talk to username (nickwilmot) on here he's doin one now... search for it there is a thread that shows good info.
Old Sep 9, 2003 | 06:04 PM
glagola1's Avatar
Do you own a helms manual? It will help greatly. The time spent on the install is going to depend of several factors. It may take weeks. I'll explain.
If the diff doesn't have a ring gear installed you will have to use the one from your current diff. This may take a while because the bolts that secure it to the diff are torqued to somewhere around 80 ft-lbs and they are REVERSE threaded. It's pretty tough to break them loose.
Secondly, you will have to shim the bearings in order to get the proper clearances in the case. When ever you change a diff in a case there is going to be a difference in tolerance and all the cases come with the size shim that was found to be correct by honda. Once you place a new diff in the case and bolt it up you will have to measure the clearances inorder to choose the right shim. The helms manual explains this procedure clearly.
So if you are going to do it right you will have to consider some down time so that you can order the correct size shim. It sucks, I know.
All in all, taking the case apart isn't that difficult but the ring gear and the shims can be a pain in the ***. If you have a helms manual and you are patient and allow for a reasonable amount of downtime, it's not too bad. I've done it and the rewards of a LSD are worth it. I'm about to go through it all again for a quaife this time.
Old Sep 9, 2003 | 06:43 PM
mugensport9's Avatar
Default Re: ctr lsd into 00si trans (glagola1)
ya it sounds like its time consuming and possibly complicated. if u havent bought the tranny u might want to look for a b series transmission with lsd.
Old Sep 9, 2003 | 10:53 PM
tangb2023
Guest
Posts: n/a
Default Re: ctr lsd into 00si trans (mugensport9)
^ i'm currently running b20b with si trans.. did not know it takes this long. a couple of weeks thanks for replies though.. anyone else did this??
Old Sep 10, 2003 | 04:16 AM
chameleon's Avatar
yeah anyone else? what about when its a quaife, differences?
Old Sep 10, 2003 | 05:07 AM
Targa250R's Avatar
be professional
Default Re: ctr lsd into 00si trans (chameleon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">yeah anyone else? what about when its a quaife, differences?</TD></TR></TABLE>
The OEM Honda LSD is a helical Torsen LSD just like the Quaife ATB.
Old Sep 10, 2003 | 05:31 AM
chameleon's Avatar
Default Re: ctr lsd into 00si trans (Targa250R)
u sure about that? thought they were clutch type and quaife was gear.
Old Sep 10, 2003 | 05:55 AM
Kengs's Avatar
Quaife is a different kind of helical than Honda OEM.
BTW, I believe you need the FD from an ITR/CTR to make the OEM LSD work with the Si tranny.
Old Sep 10, 2003 | 06:30 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">u sure about that? thought they were clutch type and quaife was gear.</TD></TR></TABLE>
No, they are both helical gear-operated LSDs.
Old Sep 10, 2003 | 07:07 AM
chameleon's Avatar
now if its a quaife made for a b16 tranny then what makes the quaife diff from a oem itr that would require the FD instead of just using the b16 FD?
and can a gsr FD be used isntead?
Old Sep 10, 2003 | 07:49 AM
Cheap Bastard's Avatar
New User
Just put one in my Si 2 weeks ago. The bolt pattern on the B16A differentials are not the same as B18C differentials.
Old Sep 10, 2003 | 08:03 AM
chameleon's Avatar
Default Re: ctr lsd into 00si trans (Cheap Bastard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cheap Bastard &raquo;</TD></TR><TR><TD CLASS="quote">Just put one in my Si 2 weeks ago. The bolt pattern on the B16A differentials are not the same as B18C differentials.</TD></TR></TABLE>
ok so what did you do in the process?
Old Sep 10, 2003 | 08:41 AM
97itr86's Avatar
Default Re: ctr lsd into 00si trans (kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">Quaife is a different kind of helical than Honda OEM.
BTW, I believe you need the FD from an ITR/CTR to make the OEM LSD work with the Si tranny.</TD></TR></TABLE>
We did my friends GSR using the stock FD. We did ctr 1,2,3 and LSD no problems with it.
Old Sep 10, 2003 | 09:12 AM
New User
I have CTR/ITR ring gears. That's the only ring gear that will fit on a CTR/ITR LSD. If you want, I have a 4.4 CTR ring gear for sale.
Old Sep 10, 2003 | 10:40 AM
glagola1's Avatar
I didn't know B16 tranny diffs had different bolt patterns. Weird.
It is possible to put the diff in the case without using the exact size shim but I do not recomend it. I guess if you didn't know about the shim and subsequent bearing clearances you could think that your install was perfect
Old Sep 10, 2003 | 12:20 PM
New User
I should clarify this. B18c/B16b have the same bolt pattern ring gear. B18b/B16a have the same bolt pattern ring gear.
Old Sep 10, 2003 | 01:32 PM
chameleon's Avatar
so how come the gsr tranny needs shimming of the case to make it fit?
Old Sep 10, 2003 | 08:28 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">so how come the gsr tranny needs shimming of the case to make it fit?</TD></TR></TABLE>
All differentials require shimming to maintain the proper clearances inside the transmission case.
Old Sep 10, 2003 | 11:29 PM
chameleon's Avatar
ok.. someone had told me they had to shim the casing..
1EG2NV
Transmission & Drivetrain
Sep 4, 2008 02:53 PM
RPRacing
Nov 14, 2005 12:27 PM
goldbrick
Dec 15, 2003 04:29 PM
nickwilmot
Sep 17, 2003 12:19 AM
Spids5
Jul 8, 2003 03:16 PM
