sqeaky drivebelt pulley thing
hey guys, i tried a search but couldnt pull anything. so my drivebelt pulley(i think thats what it is), the one on the front left side of the motor. its sqeaking... when i run the engine it seems to sway a few mm's side to side. i dont know if this is major but it just doesnt seem right. the belt seems fine and tight so i dont think doing anything to the belt would be any good.
anyway, does the pulley need replacing or could i just tighten it? thanks.
Re: sqeaky drivebelt pulley thing (ATLianIntruder)
<Your search for "squeaky belt" returned the following 5 results.>
Try spraying some belt lube on them, check the tensioner make sure the belts not too tight or too loose.
Guest
Posts: n/a
dont spray nothing on it.. only makes it worse in the long run.. check if there is oil or anything on them with a paper towel or so. then tight it up good till it stops squeaking.. if cracked get a new belt.. somtimes u think ur belt is tight but it is not.
