Installing TypeR head onto a GSR block.... how will this affect C/R??
Old Aug 20, 2001 | 09:42 AM
4drGSR's Avatar
Default Installing TypeR head onto a GSR block.... how will this affect C/R??
I'm going to be installing a TypeR head onto my GSR block. How is this going to affect my C/R? I've heard that it will lower the C/R so I'm wondering if I should use a Mugen headgasket to make up the difference? Any thoughts on this would be greatly appreciated.
TIA
Gerry
Old Aug 20, 2001 | 10:01 AM
bigTom's Avatar
Default Re: Installing TypeR head onto a GSR block.... how will this affect C/R?? (4drGSR)
it will lower it a little because the way the combustion chamber is shaped... it is a bit more open... if u want to raise it a little... u can go with a mugen headgasket... or imo id just go with higher-comp pistons
Old Aug 20, 2001 | 10:23 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Installing TypeR head onto a GSR block.... how will this affect C/R?? (ek9t)
What EK9 said.
Old Aug 20, 2001 | 12:40 PM
3rdShift.org's Avatar
New User
Default Re: Installing TypeR head onto a GSR block.... how will this affect C/R?? (B18C-EJ1)
The combustion chamber is more circular than the square-ish chambers of GSR heads resulting in more negative displacement. This will lower your compression a few tenths depending on the headgasket (& layers of headgasket) used. If you are going to have the head off, have it milled down to the compression that you desire & use a stock gasket, that way you can always use the mugen gasket if you want a tad more. If you are going to tear the entire block apart, then yes, higher compression pistons are an option.
Old Aug 20, 2001 | 10:11 PM
SpoonCivic's Avatar
New User
ditto.
might aswell upgrade the pistons if ur doing major engine work..it will save u the labour of doing it later on.
Old Aug 21, 2001 | 06:32 AM
bigTom's Avatar
also... i know it has been done... dont use a headgasket at all... dont know how or who it was that did this... but it wasnt a street car
Old Aug 21, 2001 | 08:43 AM
TypeC's Avatar
yeah, the GSR head is worth roughly .2:1 points on a B18 motor. again, it changes slightly, but that about right. so, your CR would be about 9.8:1. HTH, -C
Old Aug 21, 2001 | 03:56 PM
92Si's Avatar
New User
I guess if you like coolant mixed with your oil & a fluid covered block along with oil pressure & head temperature problems, or just don't have the cash for a headgasket this could be a solution....
Old Aug 22, 2001 | 12:37 AM
GZR4DR's Avatar
Default Re: Installing TypeR head onto a GSR block.... how will this affect C/R?? (92Si)
I would never not run a headgasket. I dont know anyone who races that doesnt have a headgasket. And i know a lot of people that are hardcore in the import scene.
Reason being is that the 2 surfaces are not perfectly flat. You could O-ring, but you would still need a headgasket.
Old Aug 22, 2001 | 08:29 AM
RyanR's Avatar
Default Re: Installing TypeR head onto a GSR block.... how will this affect C/R?? (GZR4DR)
F1 engines have no gaskets at all. The reason being that parts are machined pratically perfect. Unless you have a lot of money to pay someone to sit there an measure the entire engine and machine it perfectly I would run a headgasket.
xDicktonesx
Nov 23, 2005 09:13 AM
Newschooler
Feb 2, 2005 02:45 PM
tegasaurus
Dec 23, 2003 02:54 PM
Stunna BEN
Dec 18, 2001 08:03 AM
Hibid
Nov 27, 2001 05:45 AM
