knock sensor for a B16
Old Sep 9, 2003 | 04:09 PM
coyote's Avatar
Default knock sensor for a B16
i did my swap about a year ago and i get a CEl. It's for a bad knock sensor. now dose it hurt my motor or will it be fine? Because sometimes it will go into v tec and sometimes it wont. could this be the reason ? If so will any knock sensor work? B,D H ??or do i just need one for a B motor. thanks
Old Sep 9, 2003 | 05:06 PM
redrex91's Avatar
Default Re: knock sensor for a B16 (coyote)
it will retard the motor to prevent detination, so your car will be slightly slower,but it should not affect vtec , i had a bad one on my car for 3 months and vtec was never affected
Old Sep 9, 2003 | 05:12 PM
coyote's Avatar
Default Re: knock sensor for a B16 (redrex91)
well that is good to know thanks . ok then what could be the problem there then ?? anyone know if i can use any knock sensor from a honda ?
Old Sep 10, 2003 | 05:04 AM
coyote's Avatar
bump
Old Sep 10, 2003 | 06:09 AM
type Gendy's Avatar
I think you can only use any b series knock.
Old Sep 10, 2003 | 07:50 AM
zCivic's Avatar
Default Re: knock sensor for a B16 (sick hatchem)
I was always told knock will keep v-tec from engaging. I've seen it not engage when the knock sensor is unpluged and another guy said his still hit vtec. Dunno why or what is causing it to work and not to but those are my experiences. I just grounded the wire for mine on the therm housing like the rest of the engine harness no problems with codes here.
Old Sep 10, 2003 | 08:05 AM
ef-sihatch's Avatar
I had the same problems on my b16. First, for the vtec, change your oil or atleast make sure its full. Second, for the knock sensor, make sure that it is tight or it will throw the code. Mine was just a little loose and it threw the code right away.
Old Sep 10, 2003 | 08:49 AM
VashTheStampede's Avatar
No tears. Only dreams, now.
haha... I couldn't get my bad sensor out of my block, so I found a hole on the tranny and screwed it int there. No more knock! YAY! Oh yeah, when the car hasn't really heated up, you'll get VTEC at 5200, after the CEL code comes on, you''[ hit VTEC at around 6500 to 7000. That's about a 20hp loss. Swap it man. Too bad they're 150 bucks from Honda. Actually, just get an ECU chip from EBay. That's my .02
Old Sep 10, 2003 | 10:06 AM
coyote's Avatar
Default Re: (VashTheStampede)
i will check to see if it is loose didnt think about that . there is a shop in NJ that will chick my ecu for 150 remove the speedlimiter and take way the knock sensor just have the down time would suck 2 days with out my car . where abouts is the knock sensor anyway can i reach it under the car like when i do my oil ? on the v tec thing i don't know sometime it hit sometimes it wont i cant hear it cross over . i don't know thanks for all the help guy
Old Sep 11, 2003 | 03:56 AM
type Gendy's Avatar
Default Re: (coyote)
The knock sensor is located right above the oil filter. It is best to reach from the bottom of the car i found. If u reach up there, its a little above and to the left of the oil filter, right underneath the intake manifold, between runners 2&3.
Old Sep 11, 2003 | 05:50 AM
coyote's Avatar
Default Re: (sick hatchem)
thanks mang
Old Sep 11, 2003 | 09:24 AM
type Gendy's Avatar
No prob.......have fun :/
SingleCamin
May 19, 2009 08:23 AM
cacahead1
Jun 8, 2005 04:41 PM
codeh22a4
Apr 8, 2004 12:51 AM
DR. ON POINT
Dec 12, 2001 12:26 PM
