Garrett GT series vs Precision
Old Sep 9, 2003 | 12:00 PM
tegasaurus's Avatar
Default Garrett GT series vs Precision
I know a precision sc61 is a monster and makes amazing power. But what about the Garrett GT series turbos. a GT30 is about twice that of an SC61 but is it worth it? I recently aquired a source who can get garrett parts at cost so im thinking of getting something crazy like a GT30 .63a/r 52 trim. Don't the GT series and Precision encorporate lots of similar parts?
How much power do these things support and at about what RPM do they spool with an equal length manifold (full-race, lets say).
thanks for the comments,
Ryan
Old Sep 9, 2003 | 12:30 PM
Foozball26's Avatar
Default Re: Garrett GT series vs Precision (tegasaurus)
Precision uses Garrett wheels and makes their own housings
Old Sep 9, 2003 | 12:41 PM
tegasaurus's Avatar
Default Re: Garrett GT series vs Precision (Foozball26)
so the wheel of a gt30 and a precision sc61 would be the same - minus the ball bearings?
Old Sep 9, 2003 | 12:51 PM
PeakBoost's Avatar
B*A*N*N*E*D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">so the wheel of a gt30 and a precision sc61 would be the same - minus the ball bearings?</TD></TR></TABLE>
correct. but, it is the 56 trim gt30 wheel from the -15 gt cartridge. the 52 trim gt30 -18 cartridge is no longer available.
hope this helps
Old Sep 9, 2003 | 04:52 PM
tegasaurus's Avatar
Default Re: Garrett GT series vs Precision (CHEAPTURBOdotCOM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEAPTURBOdotCOM &raquo;</TD></TR><TR><TD CLASS="quote">
hope this helps</TD></TR></TABLE>
ken,
so, respectivly there is no difference between a gt30 and sc61 besides the trim and spool up (or will the spool up times be relatively identical).
-Ryan
Old Sep 9, 2003 | 04:58 PM
rOby's Avatar
no bb's
Old Sep 9, 2003 | 10:44 PM
Full-Race Geoff's Avatar
the gt series use a different shaft which is smaller in dia, but weighs less.
Also the GT turbines are different, the sc61 uses a stage 5 wheel, the GT uses a GT wheel.
Old Sep 9, 2003 | 10:48 PM
MikeMAN's Avatar
Default Re: Garrett GT series vs Precision (FFgeoff)
garrett makes everything, everyone else uses garrett hehe
Old Sep 9, 2003 | 11:39 PM
lazerus's Avatar
Default Re: Garrett GT series vs Precision (MikeMAN)
it's not cheap to do efficiency testing etc, as well as design of wheels...
Old Sep 10, 2003 | 12:51 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Garrett GT series vs Precision (lazerus)
My SC61 has a GT tubine wheel, but I am the only one.
Old Sep 10, 2003 | 02:30 AM
Cyber ITR's Avatar
Default Re: Garrett GT series vs Precision (Arturbo)
so in theory GT30 should make more power than SC61 in the same setup and boost level
Art : how come , i want one too
Old Sep 10, 2003 | 02:33 AM
Cyber ITR's Avatar
but if im not mistake SC61 has GT40 wheel tho not GT30 ?
Old Sep 10, 2003 | 02:40 AM
int3gra's Avatar
why do u have to mock us like that
Old Sep 10, 2003 | 03:11 AM
freakie's Avatar
Default Re: Garrett GT series vs Precision (int3gra)
the GT series spools fastrr, the new design of the wheel gives more thrust than conventional, the bal beraing makes it spool quite abit faster.
Old Sep 10, 2003 | 04:47 AM
Enthalpy's Avatar
Ken,
the SC61 uses the Compressor wheel out of the GT30R with the -0014 CHRA. The 82mm, 56 Trim GT40 compressor. The -0015 is the 76mm 56 Trim. 10 lb/min less flow. The 82mm/56 Trim can also be found iin some GT35R's.
Scott
Old Sep 10, 2003 | 09:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">My SC61 has a GT tubine wheel, but I am the only one. </TD></TR></TABLE>
so are you saying that you use a t25 center section?
Old Sep 10, 2003 | 09:17 AM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: Garrett GT series vs Precision (Enthalpy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enthalpy &raquo;</TD></TR><TR><TD CLASS="quote">
Ken,
Scott
i stand corrected. i guess i dont know the "precision" part numbers as well as i thought
thanks for clearing that up scott.
ken
branicvw
Jun 6, 2007 08:36 AM
chicken head
Oct 6, 2006 07:08 PM
Dragline
Apr 29, 2005 11:57 PM
15psi of fun
Nov 5, 2004 09:41 AM
