H22 into 94 accord, Power Steering didn't work like YOU GUYS said!!!!
Old Sep 9, 2003 | 11:58 AM
KStuned's Avatar
Default H22 into 94 accord, Power Steering didn't work like YOU GUYS said!!!!
Ok, well I just did an H22 into a 94 accord,... I used the 97 prelude power steering bracket and the 97 prelude power steering pump, because you guys said it would work with the stock power steering hose. Well it didn't work.
Well the stock power steering line didn't bolt up. So what do I do? I could have just saved money, and not had an extra power steering pump and power steering bracket.
What do I need to do to make the power steering work in a 94 accord with an H22???????
Old Sep 9, 2003 | 12:02 PM
Old Skool's Avatar
Default Re: H22 into 94 accord, Power Steering didn't work like YOU GUYS said!!!! (Hondaddict)
go to a radiator/hose shop. take the hose in and tell them you need a custom fitting. show them how its supposed to look and how long its supposed to be. it should cost 10 bux. if you cant figure that out..**** powere steering, you can feel the road better with out it anyways.
Old Sep 9, 2003 | 12:16 PM
btlfed1's Avatar
Default Re: H22 into 94 accord, Power Steering didn't work like YOU GUYS said!!!! (Old Skool)
I actually just found to fittings that would fit onto the powersteering and had a custom steel braided line made for it. works fine.
Old Sep 9, 2003 | 12:17 PM
gearhead313's Avatar
25 Year Member
I just hacked each end and welded the 2 pipes together, works like a dream
Old Sep 9, 2003 | 02:39 PM
94nvt's Avatar
Try the 97 PS. bracket and the 94Accord (your's) PS. pump!
Old Sep 9, 2003 | 02:42 PM
pdr's Avatar
pdr
I guess you didn't listen.
Use your accord pump, bracket, and THEN the 97+ prelude line.
Old Sep 9, 2003 | 03:52 PM
SearchBeforeUPost!'s Avatar
Default Re: (pdr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdr &raquo;</TD></TR><TR><TD CLASS="quote">I guess you didn't listen.
Use your accord pump, bracket, and THEN the 97+ prelude line.</TD></TR></TABLE>
what? I don't think this works at all.
I welded the prelude fitting on the end of the accord line and used the prelude pump.
Old Sep 9, 2003 | 04:19 PM
fluxion's Avatar
amin n'rangwa edanea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Old Skool &raquo;</TD></TR><TR><TD CLASS="quote">if you cant figure that out..**** powere steering, you can feel the road better with out it anyways.</TD></TR></TABLE>
have you ever driven a 5th+ gen with no power steering? that **** is insane man, i couldn't even get out of my driveway.
Old Sep 9, 2003 | 08:40 PM
94AccordCoupe's Avatar
Default Re: H22 into 94 accord, Power Steering didn't work like YOU GUYS said!!!! (fluxion)
Easy solution!! - 97 Lude bracket + Accord pump & line . Trust me this works. I just finshed my swap like a month ago. No custom line needed.
Old Sep 9, 2003 | 09:56 PM
whoa its len 2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fluxion &raquo;</TD></TR><TR><TD CLASS="quote">
have you ever driven a 5th+ gen with no power steering? that **** is insane man, i couldn't even get out of my driveway.</TD></TR></TABLE>
weaksauce.org
jk.. im running without ps and im fine. of course i flushed the lines, looped them and left a little fluid in the rack. nothing like a good forearm workout before you get to class.
Old Sep 10, 2003 | 05:20 AM
billk2k's Avatar
Default Re: H22 into 94 accord, Power Steering didn't work like YOU GUYS said!!!! (94AccordCoupe)
QUOTE=94AccordCoupe]Easy solution!! - 97 Lude bracket + Accord pump & line . Trust me this works. I just finshed my swap like a month ago. No custom line needed. [/QUOTE]
This works. I am running this no problems.
Old Sep 10, 2003 | 06:22 AM
pdr's Avatar
pdr
Default Re: (SearchBeforeUPost!)
It works. You don't need to do any welding or hose/hardline swapping.
I know the prelude bracket works w/ the accord pump, but iirc we did one on a '94 w/ the accord bracket.
btw I've been driving w/o power steering in my 5th gen for 3+ years now. My wife drives it, too. She's a massive 120lbs..oh and she manages the 6puck solid hub quite nicely, too
Old Sep 10, 2003 | 06:30 AM
b18bEG's Avatar
i dont have p.s in my 94 4 door, and its not bad at all. jsut takes a bit of muscle, when you are parking somewhre, everywhere else is good to go!
Old Sep 10, 2003 | 07:16 AM
fluxion's Avatar
Default Re: (pdr)
btw I've been driving w/o power steering in my 5th gen for 3+ years now. My wife drives it, too. She's a massive 120lbs..oh and she manages the 6puck solid hub quite nicely, too</TD></TR></TABLE>
ok ok, im a wuss
Old Sep 10, 2003 | 07:26 AM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaddict &raquo;</TD></TR><TR><TD CLASS="quote">Ok, well I just did an H22 into a 94 accord,... I used the 97 prelude power steering bracket and the 97 prelude power steering pump, because you guys said it would work with the stock power steering hose. Well it didn't work.
What do I need to do to make the power steering work in a 94 accord with an H22??????? </TD></TR></TABLE>
Whoever told you that was an idiot.
wrong power steering line
Old Sep 10, 2003 | 07:26 PM
KStuned's Avatar
Default Re: H22 into 94 accord, Power Steering didn't work like YOU GUYS said!!!! (Nick M)
I will try the accord pump w/ the 97 bracket tomorrow. Thanks guys. THIS BETTER WORK!!!
Old Sep 10, 2003 | 08:23 PM
Razor's Avatar
Default Re: H22 into 94 accord, Power Steering didn't work like YOU GUYS said!!!! (whoaitslen2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoaitslen2 &raquo;</TD></TR><TR><TD CLASS="quote">
weaksauce.org
nothing like a good forearm workout before you get to class. </TD></TR></TABLE>
Modified by Razor at 8:42 PM 9/11/2003
Old Sep 11, 2003 | 07:37 AM
AccVic's Avatar
Default Re: (tang.fung)
well I'm getting my swap done this weekend and i really want power steering but where should I look for a prelude bracket?
Old Sep 11, 2003 | 10:17 AM
pdr's Avatar
pdr
A junkyard or http://www.hparts.com
Old Sep 11, 2003 | 11:48 AM
KTeller8's Avatar
Default Re: (pdr)
did half and half like all the write ups say tool.. worked just fine for me
h22 in my 96
Speedra500
Mar 9, 2012 03:38 PM
972drcordex
Sep 23, 2005 03:18 PM
H-series LX
Oct 24, 2004 12:55 AM
95 acclude
May 17, 2004 04:03 PM
gdrum
Jan 29, 2004 12:04 PM
