Is there the slightest difference?
Old Sep 9, 2003 | 11:23 AM
Big Dick Bandit's Avatar
Default Is there the slightest difference?
Can you have an advantage from the B18a compared to the B18b or visa versa in the slightest way when doing a Ls/VTEC setup?
Old Sep 9, 2003 | 11:49 AM
I'm 2 Kewl's Avatar
Default Re: Is there the slightest difference? (Big Dick Bandit)
bump
Old Sep 9, 2003 | 12:49 PM
go2slo96's Avatar
From: im rubberband man, hondred grand in my hand man
it shouldn't matter you will get the same displacement from both. the b18a is just older.
Old Sep 9, 2003 | 12:57 PM
TECH43 RACING INC.'s Avatar
Default Re: (go2slo96)
same ****.
Old Sep 9, 2003 | 08:49 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by go2slo96 &raquo;</TD></TR><TR><TD CLASS="quote">it shouldn't matter you will get the same displacement from both. the b18a is just older.</TD></TR></TABLE>
The B18A also has an inferior head, inferior cams, inferior intake manifold, and inferior ECU. Of course, none of this matters if you go LS-VTEC.
Old Sep 9, 2003 | 09:48 PM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Dick Bandit &raquo;</TD></TR><TR><TD CLASS="quote">Can you have an advantage from the B18a compared to the B18b or visa versa in the slightest way when doing a Ls/VTEC setup?</TD></TR></TABLE>
yes........... COST i picked up my b18a long block for 200.00
Old Sep 9, 2003 | 10:41 PM
MikeMAN's Avatar
cost, go b18a if you can find it cheaper
dirt cheap i tell ya
mike
1quickTEG
Oct 7, 2005 05:53 PM
t . b o z
May 27, 2004 05:26 PM
Grease Monkey
May 12, 2004 08:20 PM
eric8876
Mar 7, 2004 04:00 PM
b16
Jul 3, 2003 06:33 AM
