How much can a B18C1 be safely bored?
Old Aug 20, 2001 | 07:27 AM
Jared's Avatar
Default How much can a B18C1 be safely bored?
Assuming stock sleeves is 82mm ok? Or is 81.5 the limit?
thanks,
Jared
Old Aug 20, 2001 | 08:23 AM
bigTom's Avatar
Default Re: How much can a B18C1 be safely bored? (Teken)
20 over aka .5mm is the max u can bore the stock sleeves... up to 81.5mm
Old Aug 20, 2001 | 12:20 PM
RyanR's Avatar
Default Re: How much can a B18C1 be safely bored? (ek9t)
Have either of you ever rebuilt a Honda engine? Have you ever even taken one apart? You can safely goto 1mm over bore. Anything more than that and you'll have to resleeve the block.
Old Aug 20, 2001 | 12:28 PM
Jared's Avatar
Default Re: How much can a B18C1 be safely bored? (97TypeR_9)
I've had several apart, but I'm worried that 1mm over would be too much for a force inducted application. What do you think?
-J
Old Aug 20, 2001 | 12:37 PM
3rdShift.org's Avatar
New User
Default Re: How much can a B18C1 be safely bored? (Jared)
.25 is the common overbore, hence factory pistons come in standard or .25 over. Having looked at a few blocks, I assume that you could bore it to 1mm over but w/ the open deck design of hondas you are going to compromise cylinder wall stability for very little improvement in displacement & power.
Old Aug 20, 2001 | 06:25 PM
RyanR's Avatar
Well for forced induction I wouldn't go over 81.5. I've ran 82mm on a NA engine and reved it to 9500 with no problems at all.
Old Aug 21, 2001 | 06:31 AM
bigTom's Avatar
i wouldnt go over 81.5mm with stock sleeves... its pushing it... why not just resleeve the block... its worth it...
as for if i have ever taken apart or put together a motor... i take apart motors almost every week and i help rebuild them (dont trust myself completely on the rebuilds yet)
Old Aug 21, 2001 | 04:58 PM
archmage's Avatar
describe the process of "resleeving" = what is actually happening here...???
And what benefits can this process get you?
Heck, what benefits does boring the block get you?
(Sorry...confused concepts in my head...)
90CB7EX
Oct 22, 2016 12:33 AM
golf-mk3
May 8, 2010 03:11 PM
EGandDArida
Sep 5, 2009 04:51 PM
Rev2 9K
Oct 5, 2005 09:07 PM
TurboxDC2
Jan 26, 2005 06:16 AM
