what gap and what plugs should i use
Old Sep 9, 2003 | 07:48 AM
99integralsturbo's Avatar
Default what gap and what plugs should i use
i have a integra ls running 6lbs of boost, what gap should i set the plugs at, the factory is .044 but that seems a little big for the turbo setup and also what kind should i get. i have NGK Rs in there now at the factory gap.
Old Sep 9, 2003 | 07:49 AM
Flamenco-T's Avatar
Default Re: what gap and what plugs should i use (99integralsturbo)
BCPRE7
gap it to .032
Old Sep 9, 2003 | 08:43 AM
96IntegraRS's Avatar
Default Re: what gap and what plugs should i use (Flamenco-T)
What about ZFR7F-11's?
Couldn't crossreference that part #.... (BCPRE7)
Old Sep 9, 2003 | 08:48 AM
quikB18B's Avatar
Default Re: what gap and what plugs should i use (96IntegraRS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96IntegraRS &raquo;</TD></TR><TR><TD CLASS="quote">What about ZFR7F-11's?
Couldn't crossreference that part #.... (BCPRE7)</TD></TR></TABLE>
Its bcpr7es-11, Stan was just being lazy I got them @ nappa the other day in stock for $1.89 a piece
Old Sep 9, 2003 | 09:45 AM
Default Re: what gap and what plugs should i use (quikB18B)
Thanks Seems like the differences between the two (bcpr7es-11 and ZFR7F-11)are the resistor, V-groove and the extended tip on the ZFR....
I guess the next question is have people found the bcpr7es-11 to be a better plug for certain applications?
Old Sep 9, 2003 | 11:25 AM
Flamenco-T's Avatar
the BCPR7ES and the BCPR7ES-11 is the same plug, the plain is pregapped to .030 ish, the -11 is pregapped .036 ish
just get whichever and gap them to .032
stan
Old Sep 9, 2003 | 11:29 AM
InTeGrA B18b1's Avatar
i use the bkr7e-11 .030 at 8 psi no detonation i think
Old Sep 9, 2003 | 11:48 AM
highmilehatch's Avatar
Default Re: what gap and what plugs should i use (InTeGrA B18b1)
I'm curious as well about the difference in these plugs. I'm currently using the bcp's. The bcp's, zfr's and bkr's are all in the 7 heat range, but what is the difference? Is one in particular more resistant to detonation?
Old Sep 9, 2003 | 12:58 PM
redlinegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">BCPRE7
gap it to .032
hit the nail on the head
integraboosted
May 2, 2006 10:33 AM
DB20
Apr 12, 2005 06:05 AM
1.8
Jan 13, 2005 07:34 PM
hybrid_vtec
15
Jul 30, 2004 01:37 PM
TuRbO_CrX_7o2
Feb 1, 2004 05:28 AM
