Oil leaking in timing belt area. H22a Help H22 people
Old Sep 9, 2003 | 06:16 AM
caliriptide's Avatar
Default Oil leaking in timing belt area. H22a Help H22 people
Ok, when the motor was out be4 the swap, these are the things that were replaced: balancer Belt & Timing, water pump, crank seal, Front Balancer seal $ cams/seals. I beleive that the oil is coming from the Drive Gear Case. I am going to buy the Gasket from Honda today.
If you look at this
It's Item 7! Do I need to reaplace the item 6 aswell????
When I first bought this H22 I pulled the oil filter, there was pieces of Gasket in it. Does anyone else or has anyone else had this problem be4????
http://www.hondaautomotivepart...AINER
Look for pic above link.
Crxh22ajdm
Mar 1, 2013 04:28 PM
Thepowderblue
May 15, 2012 06:21 PM
raverx3m
Dec 27, 2011 02:13 AM
H22Stew
Mar 12, 2008 10:48 AM
caliriptide
Sep 10, 2003 08:17 AM
