conventional oil to synthetic oil
Old Sep 9, 2003 | 03:10 AM
Behan's Avatar
Default conventional oil to synthetic oil
i've decided to run full synthetic oil and wanted to make sure i didn't have to do anything besides a regular oil change. i have been running a synthetic blend (valvoline durablend ) since i bought the car, so i don't need to mix it half and half at first, correct.
so, is there anything special i need to due or is it just a regular oil change.
Old Sep 9, 2003 | 03:21 AM
wannabe's Avatar
Default Re: conventional oil to synthetic oil (93preludevtec)
Since you already had the synthetic blend, just switch to full synthetic. Some mechanics around here say not to go straight from petroleum-based oil to full synthetic. They say go with a blend first before full synthetic.
Old Sep 9, 2003 | 05:10 AM
Sephro's Avatar
Default Re: conventional oil to synthetic oil (wannabe)
Only thing you have to do is drain the old oil and change the filter
I just swapped mine over from dino oil to synthetic. I just hit 200,000 miles this AM and I did this about 3-4k miles ago. No problems at all.
If your car has higher miles I would deff use a 10W-30 or 10W-40 rather than the 5W-30(40) for at least the 1st time.
SiYouLater
Acura TSX
Jul 27, 2007 02:36 PM
GQ 05YellowEVO8
May 24, 2002 06:25 PM
NewR
Apr 28, 2002 06:25 PM
mickey513
Oct 5, 2001 10:11 AM
TypeR01-424
Aug 17, 2001 07:51 AM
