Tranny Swapping.
Old Sep 8, 2003 | 07:09 PM
BaSiC Evil's Avatar
Default Tranny Swapping.
My 1997 JDM (right-hand drive) Prelude's auto tranny failed a couple weeks back. I am considering swapping it out to 5-speed.
Does anyone know if the shift linkage for the 4th gen and 5th gen are the same? Is the gearbox the same? Will all the pedals, ECU, harness, and cylinders work with the 5th gen?
Need as much help as possible!
Old Sep 10, 2003 | 08:02 AM
flyrod's Avatar
Default Re: Tranny Swapping. (BaSiC Evil)
Is your '97 ATTS equipped? That can be an issue. The 4th gen tranny, axels, clutch slave cylinder, flywheel, clutch etc. should work fine on the 97. I have no experience with the RHD issue. The rest of the parts may be fine, or you may have problems. There are a lot of parts you will need. The ECU will probably throw a code without the auto tranny connected, but the car should still run fine. You may be able to fake it out with a couple resistors so it think's it's hooked up to the tranny solenoids; I'm not sure on that. You can always use a manual ECU, or switch to an OBD 1 ecu. Might be able to convert OBD 2 ecus to manual, not sure on that either. I know OBD 1 can be converted. Good luck and let us know how it goes if you decide to do it...
Old Sep 11, 2003 | 03:07 AM
BaSiC Evil's Avatar
Default Re: Tranny Swapping. (flyrod)
What about the shift linkage? Will that work also?
ItalynStylion
Nov 13, 2004 02:32 PM
50shotRex
Sep 18, 2003 03:55 PM
lunarcry
Nov 23, 2002 07:51 PM
CloudDragon
Jun 26, 2002 06:43 PM
NXAccordTO4B
Apr 22, 2002 03:08 PM
