car cuts out
Old Sep 8, 2003 | 07:06 PM
11secdx's Avatar
Default car cuts out
its a 92 vx with a 96 gsr turbo motor. i was driving to work the other morning. driving along in 5th gear at about 3k rpm and the A/F gauge drops from green to red and the car falls on its face, then it goes back to green and drives fine. what could this be?
Old Sep 9, 2003 | 05:04 PM
11secdx's Avatar
Default Re: car cuts out (11secdx)
help, anyone?
Old Sep 9, 2003 | 05:10 PM
poison's Avatar
Any codes? Sounds like an O2 sensor problem.
What engine harness did you use when you swapped?
Old Sep 9, 2003 | 05:12 PM
BluePrintmfg.com's Avatar
Banned
Sounds like your fuel pump might need to be replaced soon. I had this problem on the track, it would turn on sometimes and sometimes it wouldn't. So I changed the furl pump and never had that problem again. hope this helps bro!
Old Sep 9, 2003 | 05:18 PM
11secdx's Avatar
Default Re: car cuts out (11sec.ALL MOTOR)
the car is not throwing any codes. the harness is a vx. swap has been done for atleast 2 years. i'm running a NOS fuel pump. that is straight wired to the battery, with a toggle switch as my on/off.
Old Sep 9, 2003 | 05:22 PM
poison's Avatar
So it was working fine, and now it is not correct?
Old Sep 9, 2003 | 05:36 PM
11secdx's Avatar
Default Re: car cuts out (poison)
thats exactly right. just started acting up, on the way to work last friday.
Modified by 11secdx at 3:39 AM 9/10/2003
Old Sep 12, 2003 | 02:16 PM
11secdx's Avatar
any ideas, help.
SurferDude905
Apr 1, 2017 09:47 PM
withouttrouble
Mar 21, 2012 08:08 PM
nyjdmhatch
Apr 1, 2005 04:46 PM
