Apexi SAFC
I have a Apexi SAFC its about 3-4 weeks old in great condition. Comes with the apexi instruction book and the apexi vehicle specific wiring diagram book.
I have several pictures of the unit please email me for pics
Make offer on product also
PROJECTSPEED@AOL.COM
I received some emails and pms asking what a Apexi SAFC is so i thought i would post a description
DIGITAL SUPER AFC
Piggyback Fuel Computer
Modifies air-flow meter signal (pressure signal in some vehicles) to optimize fuel-air ratio; Vacuum Fluorescent Display (VFD).
The second-generation S-AFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter/MAP sensor signal. The S-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %.
Due to the complexity of this product, A'PEX recommends having the S-AFC and other A'PEX electronics installed and tuned by authorized A'PEX Power Excel Shops.
DIGITAL SUPER AFC
TranspeedMotorsports
Aug 26, 2006 01:04 AM
