GSR rod/pisto combo fit ok into a C5 ????
Heres the deal this dude is selling a set of Eagle rods and some pistons for a GSR. I'd like to buy them but i am not sure if they will fit into my B18C5. The C5 is all stock.
Please post and help me out. thanks
Rod lengths and stroke are identical, so you can use the rods.
You'll have to check on the piston & bore size to see if the pistons are too small and if the pistons are not too small, then what kind of machining you'll need to get them to clearance properly.
