Civic Type R questions
I'm trying to find a Civic Type R head for a friend who needs it for his 99-00 Civic Si. The head has 140k on it and is shot... He got some prices on rebuilding it but I wanted to see if I could locate a head for it. And if anyone has done this swap, it is a direct fit right? Do you need to change the injectors, the fuel rail, the ECU or anything ? Any mods to head or problems? TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topspeed86 »</TD></TR><TR><TD CLASS="quote">The CTR Head is the Same as the SI what exactly are you trying to do.</TD></TR></TABLE>
ummmm, CTR head same as a Si head?? right....im hoping you are talking about how they will bolt right up...and not the actuall differences...
in terms of being a direct fit the CTR directly fits but it is not the smae thing... the CTR has different setup and is slightly more ported... so any ideas on where to locate one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris@allmotor.net »</TD></TR><TR><TD CLASS="quote">ummmm, CTR head same as a Si head?? right....im hoping you are talking about how they will bolt right up...and not the actuall differences...</TD></TR></TABLE>
Aside from the cams and valve train (which could easily be installed in a B16A head) and the slight "cleaning-up" it receives at the factory, there really aren't any differences to speak of between the two.
EDIT: Back to the original question - why not just use an ITR head?
i thought ITR does not exactly match up... something like there's a missing water port? if you do recommend the ITR matchup who has done it? any probs? mods required? place where to get one?
Basically all of the heads are the same the Type R and CTR have some what of a Factory port and they run Different Intake Valves than the SI heads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18a1boosted »</TD></TR><TR><TD CLASS="quote">the ctr head is not the same as the b16
the ctr head is the same as the itr</TD></TR></TABLE>
:smacks head:
:smacks head:
if your really in need for a civic type R head, goto.... http://store.yahoo.com/twincam....html
90B16aCRXsi
10
Dec 30, 2007 05:46 PM
Excelerate
Sep 9, 2003 02:13 AM
