Alright, I Got 84 CRX Si, I need Your help!
Old Sep 8, 2003 | 03:30 PM
NeonImpact's Avatar
Default Alright, I Got 84 CRX Si, I need Your help!
Alright, im sure this has been covered many times before and that i should search, but this is my first time here and i need immediate help..
I plan on getting a motor from Hmotorsonline.com (b16a) to put into my 84 Honda CRX SI..
After getting that stuff from them, what else should i get that is not included in their list??
I need the full breakdown of what to get, because im getting all the stuff and getting a buddy to put it in for me..
thanks alot!
-Steve
Old Sep 8, 2003 | 03:45 PM
87sivtec's Avatar
Default Re: Alright, I Got 84 CRX Si, I need Your help! (NeonImpact)
Check out the shopping list that Hasport recommends on their website.
http://www.hasport.com
Old Sep 8, 2003 | 03:57 PM
NeonImpact's Avatar
Default Re: Alright, I Got 84 CRX Si, I need Your help! (87sivtec)
hey thanks man...
ill look into it..
anyone else?
thanks again man
Old Sep 8, 2003 | 04:28 PM
crxgator's Avatar
not trying to be a dick with years of cars...but there was never an 84 Si in the US...are you sure its not an 85 si or maybe a 84 dx/hf?
Old Sep 8, 2003 | 04:30 PM
jaysonx's Avatar
PICS
Old Sep 8, 2003 | 04:45 PM
Patch's Avatar
Default Re: Alright, I Got 84 CRX Si, I need Your help! (jaysonx)
I hate to hijack, but I have the complete B-series swap kit for sale.
https://honda-tech.com/zerothread?id=613601
Old Sep 8, 2003 | 05:01 PM
NeonImpact's Avatar
Default Re: Alright, I Got 84 CRX Si, I need Your help! (Patch)
hey clubb5,
i forgot to mention to everyone..
its the 84 DX body but my friend a while back swapped the SI motor and SI harness in there for us...
sorry bro..
Old Sep 8, 2003 | 05:03 PM
NeonImpact's Avatar
hey patch, if you have AIM hit me up on NeonImpact.
anyways, are you willing to ship everything to MD?
can you give me the total to 20678?
thanks man, im REALLY interested...
Old Sep 8, 2003 | 05:07 PM
I8ayellowcrayon's Avatar
Right-O. There was no such thing as an 84 Si. Maybe its an 85....
Check out http://www.redpepperracing.com <~~ they know tons more about 1G CRXs than HT, no offense guys...
You'll need engine/tranny, ECU, motor mounts, a special shift linkage, entire wiring harness for plugs that will match up with the B, axles (not sure if you have to have some made or just use some off of a different car), and I have heard that you'll need new hubs. I'm not sure about radiator either; I'm sure you could use the stock rad, but you may need different hoses. With the bigger, heavier engine I would suggest you upgrade the torsion bars also, or just go all out and use an Integra front suspension so you can have springs up front.
Old Sep 8, 2003 | 07:22 PM
EAS VTEC's Avatar
I have the B16A swap on my 87 CRX. The hasport site was very informative and very helpfull douring my swap.
Also get the 86-89 Integra front hubs and knuckes assemblies.
If your car its a DX then you will need to convert it to FI. Get an Si harness, fuel lines or make your own, etc.
If you're using a PR3 or PWO ecu then you will need a VSS from another Honda (CRX HF, 88-91 Civic CRX, etc) another choice would be to get a ZDyne ECU.
Good luck with your car.
Old Sep 8, 2003 | 07:49 PM
NeonImpact's Avatar
Default Re: Alright, I Got 84 CRX Si, I need Your help! (EAS VTEC)
alright im gonna make a list:
I have the SI Harness already..
all this is from HASPORT.com
1. Hmotorsonline.com (motor comes from them)
2. Custom Shift Linkage (hasport)
3. Complete Axles (hasport)
4. New Gauge Cluster?
thanks for any additional listings.
Old Sep 8, 2003 | 08:00 PM
EAS VTEC's Avatar
For the gauge gluster I just used the stock CRX one, I just changed the VSS mechanism of the CRX and repaced it for a 90 CRX VSS mechanism. ( Will fit with some mods) I just connect the 2 VSS terminals ( one to ground and the other to ECU pin # B16) I did this cause Im using a PR3 ECU and need the VSS signal to activate VTEC.
Good luck
vdvirgil
Dec 16, 2010 01:27 PM
Juggalo5144
Classic Hondas
Oct 19, 2009 03:34 AM
Crxkid90
Classic Hondas
Mar 19, 2008 04:20 AM
wernhersey
May 2, 2007 11:11 PM
